Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 08-17-2013, 03:33 PM
hook hook is offline
Currently: Not set.
hook has a reputation beyond reputehook has a reputation beyond reputehook has a reputation beyond reputehook has a reputation beyond reputehook has a reputation beyond reputehook has a reputation beyond reputehook has a reputation beyond reputehook has a reputation beyond reputehook has a reputation beyond reputehook has a reputation beyond reputehook has a reputation beyond repute
Default Running a turbo at sea level
I am thinking about getting a turbo for my pro rmk. I live in Iowa so I was wondering if I can run a turbo at home as well as at elevation. I think our elevation is around 1500 feet. If so, how or what kit am I going to need to do this.
Rate this post: Yes | No
  #2
Old 08-17-2013, 04:10 PM
OFT Racing's Avatar
OFT Racing OFT Racing is offline
Currently: Not set.
OFT Racing has a reputation beyond reputeOFT Racing has a reputation beyond reputeOFT Racing has a reputation beyond reputeOFT Racing has a reputation beyond reputeOFT Racing has a reputation beyond reputeOFT Racing has a reputation beyond reputeOFT Racing has a reputation beyond reputeOFT Racing has a reputation beyond reputeOFT Racing has a reputation beyond reputeOFT Racing has a reputation beyond reputeOFT Racing has a reputation beyond repute
Garage
Default
Boost is good at any elevation. Here in Alaska we are regularly below 1500 feet. What you need to be aware of is that every 2500 feet you loose about 1 psi of atmosphere. So you can run 1 psi more boost to get the same horsepower and the engine doesn't know the difference. So for example if guys are running 8psi boost at 5k feet, at 1500 you should be running 6-7.
One other thing to take note of is that engine temp will make a engine detonate easier. So if you're running in low snow conditions you could detonate at a boost level that's safe when in snow. Error on the safe side of boost levels and run good fuel in all riding conditions.
__________________
Dealer for: Skinz Protective Gear, Timbersled Products, Yamaheater, Z Broz, Curve Industries, Elka Shocks, DynoJet products
Email; Rick@OFTRacing.com
www.facebook.com/OverTheTopSledParts
  #3
Old 08-17-2013, 08:23 PM
w2bridin w2bridin is offline
Currently: Not set.
w2bridin has a reputation beyond reputew2bridin has a reputation beyond reputew2bridin has a reputation beyond reputew2bridin has a reputation beyond reputew2bridin has a reputation beyond reputew2bridin has a reputation beyond reputew2bridin has a reputation beyond reputew2bridin has a reputation beyond reputew2bridin has a reputation beyond reputew2bridin has a reputation beyond reputew2bridin has a reputation beyond repute
Default
My m8T runs great at 900ft here in ND. Talk to Silber turbos they are in MN and do mainly Polaris.
  #4
Old 08-18-2013, 06:53 PM
Currently: Not set.
Default
I had talked to someone and was told that with a boondocker kit, I could set up the sled at my elevation and then head to the mountains and wouldn't have to touch a thing if I had the ebc. Is this true? If so, that would be great for me so I don't have to spend a lot of my first trip tuning. Thanks for the help so far.
  #5
Old 08-18-2013, 07:11 PM
xcmark's Avatar
xcmark xcmark is offline
Currently: cutting grass waiting for snow
xcmark has a reputation beyond reputexcmark has a reputation beyond reputexcmark has a reputation beyond reputexcmark has a reputation beyond reputexcmark has a reputation beyond reputexcmark has a reputation beyond reputexcmark has a reputation beyond reputexcmark has a reputation beyond reputexcmark has a reputation beyond reputexcmark has a reputation beyond reputexcmark has a reputation beyond repute
Default
there is a thread about 2 months ago on this topic , If I had the money Sliber was what I would do. with the 2014 bullydog control and the slightly looser 63 size turbo that hits softer but puts less heat into the charge air.
  #6
Old 08-18-2013, 09:00 PM
die hard poo's Avatar
die hard poo die hard poo is offline
Currently: Waitin' for snow...
die hard poo has a reputation beyond reputedie hard poo has a reputation beyond reputedie hard poo has a reputation beyond reputedie hard poo has a reputation beyond reputedie hard poo has a reputation beyond reputedie hard poo has a reputation beyond reputedie hard poo has a reputation beyond reputedie hard poo has a reputation beyond reputedie hard poo has a reputation beyond reputedie hard poo has a reputation beyond reputedie hard poo has a reputation beyond repute
Default
Quote:
This is the setup I am running this year on my 14' pro. 14' Silber kit with the bullydog and the KPA 63 billet wheel and at sea level. I hope it runs as good as advertised. Planning on running 10-12 psi on avgas. I will let ya know how it runs when I get it.
__________________
16-AXYS PRO RMK 800 155 3"-
17-SUMMIT X 850 154 3"-
  #7
Old 08-22-2013, 08:24 PM
TurboMatt TurboMatt is offline
Currently: thinking
TurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond repute
Default
I have the '12 Silber Kit on a '11 Pro. I run 5-6psi at 1000ft elevation on 100LL gas.
I could probably get away running less octane, but for me it's just easier and hardly more expensive to just run straight 100LL all the time.
__________________
'11 T-Pro
  #8
Old 08-23-2013, 01:13 PM
Sunvang Sunvang is offline
Currently: Not set.
Sunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond repute
Default
My 2013 Assault with standard Boondocker turbo kit at near sea level. Straight pump gas and RkTek turbo head and pistons.
http://youtu.be/yielmVBdbZY
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — anybody running at sea level on pump gas at 5psi Thread Starter — mentlsled Forum — Arctic Cat: TURBO Replies — 6 Last Post — 01-24-2013 01:54 PM
Thread — Sea level turbo kits? any out there? Thread Starter — s.e.xtreme Forum — Ski-Doo: TURBO Replies — 6 Last Post — 12-27-2012 05:57 PM
Thread — Anybody running a turbo on '12 800cc @ Sea Level? Thread Starter — Mr. Pump Gas Forum — Polaris: TURBO Replies — 30 Last Post — 11-10-2012 01:41 PM
Thread — Anyone running an Turbo on '12 800cc @ Sea Level? Thread Starter — Mr. Pump Gas Forum — Polaris: Pro-Ride Replies — 7 Last Post — 03-13-2012 01:04 PM
Thread — Running turbo at sea level or close to it??? Thread Starter — herme01 Forum — Polaris: TURBO Replies — 11 Last Post — 05-13-2010 09:59 PM
