Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 11-03-2012, 05:30 PM
strong strong is offline
Currently: Not set.
Basic Member
strong has a reputation beyond reputestrong has a reputation beyond reputestrong has a reputation beyond reputestrong has a reputation beyond reputestrong has a reputation beyond reputestrong has a reputation beyond reputestrong has a reputation beyond reputestrong has a reputation beyond reputestrong has a reputation beyond reputestrong has a reputation beyond reputestrong has a reputation beyond repute
Garage
Default is there a way to test a servo motor?
my 07 m8 throws the 1:8 code, my cables were burned from the pipe so i replaced both cables and set them to the 35mm as required, i also rerouted my wires from under the tank, to in front of the tank. Got the sled all put back together and pulled it over, once i get over 5,000 rpm the i get a 1:8 flash again. I had a servo motor form an m1000 that i put on there just to see if I would get same response, and i did. idk if i am able to put the m1 servo on the m8 but they had the same wires.
Any advice on how to get this resolved?
Rate this post: Yes | No
  #2
Old 11-03-2012, 05:38 PM
RACINSTATION's Avatar
RACINSTATION RACINSTATION is online now
Currently: Getting Excited for the 2018 CAT!
RACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond repute
Default
Same servo motor on the M8 and M1000
Make sure that you are at 35mm of EXPOSED cable and also make sure they are not hanging up or really dirty in the cylinders.
Not at the shop right now, but you can ohm test the motor to make sure it is good.
__________________
The Racin Station
60 South 1st Street Driggs, Idaho 83422
Ph: 208-354-2777 E-Mail: racinstation@hotmail.com
The Racin Station is your TURBO MOD HEADQUARTERS
for Arctic Cat Proclimb 8000/1100 and Yamaha Vipers and Sidewinders!
TIMBERSLED FULL LINE DEALER!!!
Proclimb Carbon Fiber Vents
Your MDS weight headquarters
Team ProClimb secondary complete setups ready!
Reman M6,M7,M8 and M1000 cylinders in stock.
Jaws M8 Singles for the 2012-2017 in stock!
Jacobsen Rollover valves in stock for M1100Turbo and Viper/M7000!!
Camoplast 3" and 3.2" 174, 162 and 156 x15 tracks on hand now
The Following User Says Thank You to RACINSTATION For This Useful Post:
strong (11-04-2012)
  #3
Old 11-04-2012, 07:23 AM
firecat99 firecat99 is offline
Currently: Not set.
Basic Member
firecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond repute
Garage
Default
you put the cables on the right side? I was getting a code like that last season on my 09 CF 600 and with my cables set right it was still giving me a code so i tightened them up a 1/4 at a time and it finally went away. The new systems are alot more touchy then the older ones.
The Following User Says Thank You to firecat99 For This Useful Post:
strong (11-04-2012)
  #4
Old 11-04-2012, 10:07 AM
Currently: Not set.
Basic Member
Garage
Default
Quote:
good question, i noticed that they could go on both sides. and taking it all apart then waiting for parts for a week, this is a good possibility. when you are looking at the servo, do they go in the clutch "right" or the can "left?"
  #5
Old 11-04-2012, 01:28 PM
Currently: Not set.
Basic Member
Garage
Default
went and checked another m sled to see which side the cables are ran, sure enough i had mine on the wrong side started it up and ran like a champ. Thanks a ton..
Now bring on the snow.
  #6
Old 11-05-2012, 08:37 AM
Currently: Not set.
Basic Member
Garage
Default
lol Good to hear, I only know this as i have done it a few times years ago and we were scratching our heads for a while trying to figure out on the older models (they dont always flash a code) and you would get no top end and motor felt like it was loading up.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Servo Motor Thread Starter — TPDP32 Forum — WTB (Swapmeet) Replies — 1 Last Post — 05-28-2012 09:25 PM
Thread — Servo - Motor Thread Starter — TPDP32 Forum — Arctic Cat: M Series Replies — 0 Last Post — 05-21-2012 09:13 PM
Thread — servo motor Thread Starter — kbest.1990 Forum — Arctic Cat: 1M Replies — 17 Last Post — 01-19-2012 12:37 AM
Thread — M-7 Servo Motor cables popping out of motor Thread Starter — snodad Forum — Arctic Cat: M Series Replies — 6 Last Post — 10-19-2009 09:49 PM
Thread — Servo Motor Thread Starter — tube Forum — Arctic Cat Replies — 2 Last Post — 09-23-2008 09:28 PM
