Mpi 180 upgrade
Yes they offer one. 230 from what I understand. Haven't seem one , but Im sure MPI will hop on here to explain........or just contact them.
Cheers
RS
intercooler
basically you will need a Stage 1 Upgrade kit....intercooler, reflash of the gems. I believe they will run you about 1,000.
I'm upgrading mine right now to the 230hp mark. The upgrade is a intercooler, re flash of the gems, new waste gate. I'm also gonna pull the engine and put in a head shim, adjust the cam timing with powder litres jig. And upgrade the fuel pump. The head shim will give me the ability to run lower octane fuel rather than expensive race gas. Can always use av fuel too. Cost me about $1800. Fuel pump being around the $800 mark
Why the hell would a fuel pump cost $800, is it made of gold or something?
http://www.snowest.com/forum/showthread.php?t=352615
Check this earlier post. I'm running a special right now for guys doing it before we start to get crazy. You could choose to do a head shim to run on pump gas or we could re-flash your Yamaha ECU with a reduced timing program and it would do the same thing as a shim without missing up the bottom end performance and without opening up your motor. I don't know about a fuel pump that costs around $800? Our fuel pump kit is $399 and includes a billet return block, billet regulator adaptor, Walbro pump, and 1/1 regulator.
im sorry but a fuel pump being $800, your kidding right?
Oops, dang ipad. No my mistake, the fuel pump was $400. Although I do wish it was made of gold
I know our pump is expensive but its not make of gold! Here is some more info on our kit.
MPI fuel pump upgrade. Part#HSK-1237 $399.95. In stock ready to ship.
The kit has everything you need to upgrade the stock Nytro fuel pump. We have made several billet parts to make this a easy "factory looking" upgrade. Included are a Walbro pump, billet fuel return fitting, fuel regulator, billet req. adaptor, high pressure fuel line, clamps, fuse, and illustrated instructions.<O:p</O:p
Yeah now that's a little better---$400 bucks.
So Matt what kind of boost and Hp can a guy safely run with the fuel pump upgrade as well as the intercooler?
