Upgrade to Premium
Reply
  #1
Old 05-09-2012, 08:10 AM
type_a_positive's Avatar
type_a_positive type_a_positive is offline
Currently: Bouncin` the rev limiter
type_a_positive has a reputation beyond reputetype_a_positive has a reputation beyond reputetype_a_positive has a reputation beyond reputetype_a_positive has a reputation beyond reputetype_a_positive has a reputation beyond reputetype_a_positive has a reputation beyond reputetype_a_positive has a reputation beyond reputetype_a_positive has a reputation beyond reputetype_a_positive has a reputation beyond reputetype_a_positive has a reputation beyond reputetype_a_positive has a reputation beyond repute
Default 200+ HP clutch setups, discussion/post them here
Hi.
I have had limited luck with my clutch setups for my 1100 turbo with 2.5" DV outlet and exhaust, Hi-Jacker2.0, intercooler fan and vented all over, set at about 230 HP
Have tried the Daltons 5Ws weights, different primary springs and a 38/46 progressive helix.
Now I am running 96 grms MDS weights in the primary with a cat gold spring, and a stock secondary except for hi-torque rollers. Kinda works, but have to reduce boost on my Hi-Jacker to stay off rev limiter. Also, the rpms fluctuates alot more then my piped/head modded M1000 did.(7400-8000, the M1000 stayed at 7500-7600) Would like it to hold a steady 7800-7900.
I am concerned that the cat gold spring might not be stiff enough to control the heavy weights, but steve at MDS recommends this setup.
A torsion setup and floating the secondary are options I am looking into right now. I have heard that they might limit some of the excessive clutch heat but I have not been convinced on either yet.
Thanks for looking.
-t
__________________
Proclimb 1100T SP 162, remapped and GEARED UP!
Bearcat Z1 XT, Jaguar Z1, Ski-Doo GT 500F
Rate this post: Yes | No
  #2
Old 05-09-2012, 11:44 AM
Turbo11T's Avatar
Turbo11T Turbo11T is offline
Currently: EVOLVING
Turbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond repute
Default
Quote:
Originally Posted by type_a_positive View Post
Hi.
Thanks for looking.
-t
I have a poo black spring in mine from MDS. . . I am not over 200 hp though. I am very consistant on rpm though. Your inconsistancy could be coming from the fact that at 230 hp your little turbo is probally creating so much heat.
__________________
2014 Ski Doo Summit XM Turbo
-154
-Silber turbo
-Boost-It XIC
-DJ Clutching
-AWESOME
  #3
Old 05-09-2012, 01:04 PM
Default
Forgot to mention that I am at 0-3000ft
__________________
  #4
Old 05-09-2012, 05:46 PM
damx damx is online now
Currently: Not set.
damx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond repute
Default
I ride @ 0-4000 feet. I have td reflash running about 260hp and have 86g. Mds weight with a black Polaris spring 100/340. And a 36/42 p helix. Holds 8400 all day long.
  #5
Old 05-10-2012, 02:12 AM
Default
Quote:
86 grms? If I remember correctly, the TD reflash raises the rev limiter to 8600?
Still, with those light weights at 260hp, how do you stay of the limiter when you grab a handfull of throttle?
__________________
  #6
Old 05-10-2012, 07:19 AM
Currently: Not set.
Default
No the td reflash raises the rev limiter to 9000 rpm, when I grab a hand full of gas it will jump too 8600 then drop too 8300 too 8400 right away and stay there.
  #7
Old 05-10-2012, 08:33 AM
4mcntrls's Avatar
4mcntrls 4mcntrls is online now
Currently: Still at the lake, still waiting for the snow!
4mcntrls has a reputation beyond repute4mcntrls has a reputation beyond repute4mcntrls has a reputation beyond repute4mcntrls has a reputation beyond repute4mcntrls has a reputation beyond repute4mcntrls has a reputation beyond repute4mcntrls has a reputation beyond repute4mcntrls has a reputation beyond repute4mcntrls has a reputation beyond repute4mcntrls has a reputation beyond repute4mcntrls has a reputation beyond repute
Default
TD reflash 2.5 camo extreme I am running about 94 grams of Dalton's I had 90 in it and I would blow right through my rev limiter
__________________
2013 Pro-Climb Ltd. 800 162 X2
2013 KX450 C/W Timbersled ST
  #8
Old 05-10-2012, 10:24 AM
Default
Quote:
Stock primary spring? Stock secondary? And may I ask which TD program?
__________________
  #9
Old 05-13-2012, 11:00 AM
madmax madmax is offline
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
Default
Hi.
Thanks for looking.
-t
What are you trying to accomplish with a different clutch set up? Do you know where the peak HP and torque is for your motor with the mods you have?
  #10
Old 05-13-2012, 03:37 PM
Buz Buz is online now
Currently: Which ways up!
Buz has a reputation beyond reputeBuz has a reputation beyond reputeBuz has a reputation beyond reputeBuz has a reputation beyond reputeBuz has a reputation beyond reputeBuz has a reputation beyond reputeBuz has a reputation beyond reputeBuz has a reputation beyond reputeBuz has a reputation beyond reputeBuz has a reputation beyond reputeBuz has a reputation beyond repute
Default
I think the only way your going to stay off the rev limiter is to reflash or try the primary shim kit. I may send mine in over the summer to D & D but, waiting to see what else comes up. I think this year was only the start of some great set ups. I was running 98 grams and still hitting the rev limiter.
__________________
Pin IT
  #11
Old 05-14-2012, 02:59 AM
Click Here to Register
  #12
Old 05-14-2012, 03:04 AM
The Following User Says Thank You to type_a_positive For This Useful Post:
damx (05-14-2012)
  #13
Old 05-16-2012, 06:54 AM
  #14
Old 06-03-2012, 04:49 PM
  #15
Old 06-03-2012, 08:56 PM
JustBoostIt's Avatar
JustBoostIt JustBoostIt is offline
Currently: Enjoying the builds
JustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond repute
  #16
Old 06-05-2012, 09:03 AM
  #17
Old 06-05-2012, 06:29 PM
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 8 clutch setup Please post your M8 clutching setups Thread Starter — Ken Climb Forum — Arctic Cat: M Series Replies — 24 Last Post — 11-16-2010 06:45 PM
Thread — Please post XP clutch setups Thread Starter — bigbird Forum — Ski-Doo Replies — 1 Last Post — 12-20-2008 07:18 PM
Thread — 200 hp for sale Thread Starter — hurtinalbertin Forum — Arctic Cat (Swapmeet) Replies — 0 Last Post — 03-19-2008 03:22 PM
Thread — AC Mod 200+ HP Thread Starter — S3 Ent Forum — Arctic Cat (Swapmeet) Replies — 1 Last Post — 03-12-2008 08:47 AM
