Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 03-03-2012, 12:29 PM
Jeff95's Avatar
Jeff95 Jeff95 is offline
Currently: Not set.
Jeff95 has a reputation beyond reputeJeff95 has a reputation beyond reputeJeff95 has a reputation beyond reputeJeff95 has a reputation beyond reputeJeff95 has a reputation beyond reputeJeff95 has a reputation beyond reputeJeff95 has a reputation beyond reputeJeff95 has a reputation beyond reputeJeff95 has a reputation beyond reputeJeff95 has a reputation beyond reputeJeff95 has a reputation beyond repute
Default 2013 Front (Ski) Shock Length
Anyone get to measure the 2013 Pro Front (Ski) Shock extended Length?
I just got Fox Evol R for my 09 dragon and hope they fit on the 13 pro.
I thought I read that the 13 where shorter than the 12. So my new foxz's are 17" C/C extended.
Thanks
Jeff
Rate this post: Yes | No
  #2
Old 03-03-2012, 01:59 PM
ak ak is online now
Currently: Nothing
ak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond repute
Default
The 12s are 17.5 so you should be good.
  #3
Old 03-03-2012, 02:37 PM
racerjb racerjb is offline
Currently: Not set.
racerjb has a reputation beyond reputeracerjb has a reputation beyond reputeracerjb has a reputation beyond reputeracerjb has a reputation beyond reputeracerjb has a reputation beyond reputeracerjb has a reputation beyond reputeracerjb has a reputation beyond reputeracerjb has a reputation beyond reputeracerjb has a reputation beyond reputeracerjb has a reputation beyond reputeracerjb has a reputation beyond repute
Default
I read somewhere that they might have changed from the 2012 to the 2013. Not sure if it was just the mounting location on the new arms or a shock change length. It looks like Carls Cycle has one at their shop so maybe they could let us know.
  #4
Old 03-03-2012, 09:23 PM
mountainhorse's Avatar
mountainhorse mountainhorse is online now
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
Default
The new 2013 Pro RMK shock is almost an inch shorter than the 11/12' Pro.
2013 PRO RMK is 16.63" extended (Center to Center length)
2011/12 PRO RMK is 17.50" extended
A Dragon/IQ is 17.20" extended.
Some of this is because of the new design lower a-arm on the 13 which has a higher mounting point on the a-arm for the lower shock eye... I think that the 13 also dropped the ride height in the front a bit... which may account for some improved handling character of the sled.. but I have no solid info on that.
I'm not sure on the Standard RMK... that info is not available yet.
Your Foxes for the Dragon would fit... but would raise the ride height..plus you would need to enlarge the holes in the shock reducer bushings to 10mm.
You could send them into a good fox shop and get them shimmed to reduce the extended length... but that would also reduce the total travel... The PRO RMK evol R's also have a different valving package.
__________________
Signature:
The Following 3 Users Say Thank You to mountainhorse For This Useful Post:
diamonddave (03-04-2012), racerjb (03-04-2012), vermilion (03-07-2013)
  #5
Old 03-04-2012, 01:14 PM
B2's Avatar
B2 B2 is online now
Currently: Waiting for snow...
B2 has a reputation beyond reputeB2 has a reputation beyond reputeB2 has a reputation beyond reputeB2 has a reputation beyond reputeB2 has a reputation beyond reputeB2 has a reputation beyond reputeB2 has a reputation beyond reputeB2 has a reputation beyond reputeB2 has a reputation beyond reputeB2 has a reputation beyond reputeB2 has a reputation beyond repute
Default 2012 A-arms on 2013?
MH, are the inner mounting locations the same on a 2013? I see the swaybar mount is different, but if I have a set of aftermarket a-arms on a 2012, would they fit on the 2013, mount up with the swaybar and be able to keep/use the high end shocks I have on my 2012?
__________________
2013 PRO RMK 163
  #6
Old 03-04-2012, 02:13 PM
Default
Yes.. Your entire front end from the 2012 will swap over to the 2013... including A-arms and shocks.
Pics of the two front ends... 2012 first
Notice that the 2013 lower is mounted inboard and higher with the aluminum end forging.
__________________
Signature:
The Following User Says Thank You to mountainhorse For This Useful Post:
B2 (03-04-2012)
  #7
Old 03-04-2012, 05:02 PM
Jeff95's Avatar
Currently: Not set.
Default
After looking at the 2013 swaybar mount. Is that mount glued to the arm? Is the glue really that strong?
Do you think the valving would be worth changing?
I know my dealing with Fox with my mountain bikes have been really good. So maybe I could send them in to get revalved if its not to much money!
I'm still liking my dragon. But have to say my last ride out I was with two guys on 2012 pro's. We where in 3-4' freash snow and early in the day I had no problem going and staying with them. But later in the day after it warmed up my dragon was pushing more snow and trentching (Getting Stuck). The pro's got right up on top and tractored circle around me!!
Jeff
  #8
Old 03-04-2012, 07:55 PM
t stone t stone is offline
Currently: In the steep and deep!
t stone has a reputation beyond reputet stone has a reputation beyond reputet stone has a reputation beyond reputet stone has a reputation beyond reputet stone has a reputation beyond reputet stone has a reputation beyond reputet stone has a reputation beyond reputet stone has a reputation beyond reputet stone has a reputation beyond reputet stone has a reputation beyond reputet stone has a reputation beyond repute
Default
Ya and then he T Boned his buddy. LOL, ouch!
Stone
  #9
Old 03-04-2012, 09:25 PM
Default
Just noticed... the 2013 has jounce bumpers on the Ski Shocks...
And the lower shock-rod-eye is shorter/smaller..........Hmm
__________________
Signature:
  #10
Old 03-05-2012, 01:20 PM
Jeff95's Avatar
Currently: Not set.
  #11
Old 03-05-2012, 02:43 PM
FCR112 FCR112 is offline
Currently: Not set.
FCR112 has disabled reputation
Click Here to Register
  #12
Old 03-05-2012, 04:25 PM
800poodragon's Avatar
800poodragon 800poodragon is offline
Currently: Not set.
800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute
Garage
  #13
Old 03-05-2012, 10:38 PM
Reg2view Reg2view is offline
Currently: Not set.
Reg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond repute
  #14
Old 03-05-2012, 11:21 PM
Currently: Not set.
  #15
Old 03-06-2012, 03:28 AM
800poodragon (03-06-2012)
  #16
Old 03-06-2012, 10:47 AM
AKRMK25 AKRMK25 is offline
Currently: Doing a snow dance!
AKRMK25 has a reputation beyond reputeAKRMK25 has a reputation beyond reputeAKRMK25 has a reputation beyond reputeAKRMK25 has a reputation beyond reputeAKRMK25 has a reputation beyond reputeAKRMK25 has a reputation beyond reputeAKRMK25 has a reputation beyond reputeAKRMK25 has a reputation beyond reputeAKRMK25 has a reputation beyond reputeAKRMK25 has a reputation beyond reputeAKRMK25 has a reputation beyond repute
  #17
Old 03-06-2012, 10:57 AM
Jeff95's Avatar
Currently: Not set.
  #18
Old 03-07-2013, 07:15 PM
vermilion vermilion is offline
Currently: Not set.
Basic Member
vermilion is an unknown quantity at this point
  #19
Old 03-07-2013, 08:11 PM
ak ak is online now
Currently: Nothing
The Following User Says Thank You to ak For This Useful Post:
vermilion (03-08-2013)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — M1100t front shock length Thread Starter — PIKER Forum — Arctic Cat: 1100 ProClimb Replies — 2 Last Post — 12-13-2011 10:42 AM
Thread — m-series front float shock length Thread Starter — smp747 Forum — Arctic Cat: M Series Replies — 4 Last Post — 11-19-2010 02:19 PM
Thread — Front Shock Length? Thread Starter — AKLankford Forum — Ski-Doo: XP Sleds Replies — 1 Last Post — 11-09-2009 10:01 PM
Thread — Apex Front Shock Length ? Thread Starter — Duke Forum — Yamaha Replies — 2 Last Post — 08-22-2008 08:03 AM
Thread — M10 front shock length ? Thread Starter — Duke Forum — Yamaha Replies — 0 Last Post — 06-14-2008 12:10 PM
