Upgrade to Premium
Ski-Doo: REV Sleds 2004.5-200, all models in the REV chassis
Reply
  #1
Old 01-17-2012, 10:44 AM
Hockaday Hockaday is offline
Currently: Not set.
Hockaday has a reputation beyond reputeHockaday has a reputation beyond reputeHockaday has a reputation beyond reputeHockaday has a reputation beyond reputeHockaday has a reputation beyond reputeHockaday has a reputation beyond reputeHockaday has a reputation beyond reputeHockaday has a reputation beyond reputeHockaday has a reputation beyond reputeHockaday has a reputation beyond reputeHockaday has a reputation beyond repute
Default Ball joint removal
My buddy is having issues removing the ball joint from the aluminum bracket. Does anyone have any recommendations on the best way to break those pieces apart. The aluminum bracket is not bent or broken, but the bottom a-arm is trashed. He has supposedly try everything except heat. Any ideas?
Rate this post: Yes | No
  #2
Old 01-17-2012, 12:45 PM
Danzick Danzick is offline
Currently: Not set.
Basic Member
Danzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond repute
Garage
Default
a puller worked for me if i remember right. i just had a cheap 2 arm puller i put the arms on the aluminum spindle and the middle of the puller on the bolt. if that doesn't work or he doesn't have one get a junk nut and a lot of WD 40 and beat it off. not many options.
  #3
Old 01-26-2012, 10:34 AM
linstro7 linstro7 is offline
Currently: Not set.
Basic Member
linstro7 is an unknown quantity at this point
Default
So, I am the buddy Hockaday is talking about. I ended up getting it but is was a pain in the ***. Just in case anyone else has the same issue figured I would update so it might help you. I ended up getting a set of ball joint tools from Tool King for about $13 that ended up doing the trick. I had to beat the **** out of it but it finally poped out of the aluminum spindle. Spend the $13 up front and dont waste your time trying other pullers etc.
The Following User Says Thank You to linstro7 For This Useful Post:
blacksnow (01-26-2012)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Help! I need an 04-07 Summit lower ball joint Thread Starter — towny Forum — Ski-Doo: REV Sleds Replies — 1 Last Post — 03-09-2011 10:00 AM
Thread — How do you install ball joint on lower A-arm? Thread Starter — rjkoll Forum — Polaris: IQ Replies — 10 Last Post — 01-20-2011 10:08 AM
Thread — Trailing arm plastic ball joint Thread Starter — davermk Forum — Polaris: EDGE Replies — 8 Last Post — 01-26-2010 08:53 PM
Thread — Taking out Ball joint in Phazer A-Arms Thread Starter — Visi Forum — Phazers! Replies — 0 Last Post — 11-28-2007 09:03 PM
