Upgrade to Premium
Polaris: IQ 2005-Current, all models in the IQ and IQ Raw chassis
Reply
  #1
Old 02-21-2011, 08:17 PM
poledge800 poledge800 is offline
Currently: need more snow!!
poledge800 has a reputation beyond reputepoledge800 has a reputation beyond reputepoledge800 has a reputation beyond reputepoledge800 has a reputation beyond reputepoledge800 has a reputation beyond reputepoledge800 has a reputation beyond reputepoledge800 has a reputation beyond reputepoledge800 has a reputation beyond reputepoledge800 has a reputation beyond reputepoledge800 has a reputation beyond reputepoledge800 has a reputation beyond repute
Default exhaust valve solenoid
how do they exactly work
my check engine came on and i hooked it up to a computer and it said it was the exhaust valve solenoid so i took it off and cleaned it up and put it back on cleared the code and went out and rode it for a bit the light never came on
then i shut it off for a while and went back to ride it some more and it came back on and has no bottom end its like the valves open manually like the edges
what usually goes out on them
Rate this post: Yes | No
  #2
Old 02-21-2011, 08:35 PM
WStilson WStilson is offline
Currently: Eastern Idaho
Basic Member
WStilson has a brilliant futureWStilson has a brilliant futureWStilson has a brilliant futureWStilson has a brilliant futureWStilson has a brilliant futureWStilson has a brilliant futureWStilson has a brilliant futureWStilson has a brilliant futureWStilson has a brilliant futureWStilson has a brilliant futureWStilson has a brilliant future
Default EVS
How did you hook your sled to a computer???
The exhaust valve solenoid closes at 6800-7200 RPM allowing pressure to build in the valves and opening them. The ECU looks for 15 ohms from the solenoid to see if it is there.
If it says your solenoid is bad, check the wires and check for 15 ohms on the solenoid.
Idaho Bill
  #3
Old 02-21-2011, 09:57 PM
Default
my neighbor has one
do they usually go out
  #4
Old 02-22-2011, 11:17 AM
Basic Member
Default EVS
Did you check the wiring to the solenoid? Did you check for 15 ohms?
I would like more information on how your neighbor's computer is set up!
Where did he get the cable and the software to talk to the ECU?
Thanks,
Idaho Bill
  #5
Old 02-22-2011, 02:07 PM
jim9006 jim9006 is offline
Currently: At the ranch
jim9006 has a reputation beyond reputejim9006 has a reputation beyond reputejim9006 has a reputation beyond reputejim9006 has a reputation beyond reputejim9006 has a reputation beyond reputejim9006 has a reputation beyond reputejim9006 has a reputation beyond reputejim9006 has a reputation beyond reputejim9006 has a reputation beyond reputejim9006 has a reputation beyond reputejim9006 has a reputation beyond repute
Default
It can be found online at http://polaris.spx.com/
You'll need your dealer to get for you.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Exhaust valve system dump valve Thread Starter — 906 Bob Forum — Polaris: IQ Replies — 16 Last Post — 11-01-2011 01:33 AM
Thread — Exhaust Valve Solenoid Leaking Oil Thread Starter — outlaw700 Forum — Polaris: 900 Replies — 5 Last Post — 11-21-2010 10:26 AM
Thread — VES Vacum Solenoid Valve ? Thread Starter — SixtySevenGT Forum — Polaris: 900 Replies — 5 Last Post — 04-06-2010 10:10 PM
Thread — DPM Solenoid Valve Thread Starter — summitX09 Forum — Ski-Doo: XP Sleds Replies — 1 Last Post — 12-05-2009 09:10 AM
Thread — 900 RMK coils and power valve solenoid. Thread Starter — WFO or go home Forum — Misc. Sled Parts Replies — 0 Last Post — 07-22-2008 03:01 PM
