Upgrade to Premium
Yamaha: Boosted Sleds (Turbo or Supercharged) Turbo discussion for Yamaha aftermarket Turbo or Super Charged sleds.
Reply
  #1
Old 01-06-2011, 05:21 PM
bdoe22 bdoe22 is offline
Currently: Husky 501 LTSX
Basic Member
bdoe22 has a reputation beyond reputebdoe22 has a reputation beyond reputebdoe22 has a reputation beyond reputebdoe22 has a reputation beyond reputebdoe22 has a reputation beyond reputebdoe22 has a reputation beyond reputebdoe22 has a reputation beyond reputebdoe22 has a reputation beyond reputebdoe22 has a reputation beyond reputebdoe22 has a reputation beyond reputebdoe22 has a reputation beyond repute
Default CODE 46 NYTRO
2010 NYTRO. PUSH 180 KIT. SLED QUIT RUNNING WHILE OUT RIDING IN DEEP POWDER, AND WOULDNT EVEN CRANK. THREW A CODE 46-LOW/HIGH VOLTAGE. AFTER A LONG TOW BACK, GOT IT BACK TO THE SHOP, AND AFTER SOME INVESTIGATION, THE STARTER WAS COMPLETELY FRIED....LOCKED UP TIGHT AND STUNK BAD. SOMETHING CAUSED IT TO STAY ENGAGED AND I ASSUME DRAINED THE BATTERY SO LOW THAT IT WOULDNT FIRE THE INJECTORS. ANYBODY HEARD OF THIS OR SEEN ANY PROBLEMS WITH THE SOLENOID OR STARTER? WARRANTY COVERED THE STARTER, SOLENOID, CABLE, LABOR AND EVERYTHING FOR DIAG. JUST WONDERING IF ANYBODY HAS SEEN PROBLEMS WITH THIS.
Rate this post: Yes | No
  #2
Old 01-07-2011, 05:12 PM
Basic Member
Default update
starter was totally fried from heat not from spinning! melted the solder inside the starter, but the armature seems ok. not sure what caused this, but wanting to find a fix before it goes back on the snow.
  #3
Old 01-07-2011, 05:19 PM
Summitseeker's Avatar
Summitseeker Summitseeker is offline
Currently: thinking about snow
Summitseeker has a reputation beyond reputeSummitseeker has a reputation beyond reputeSummitseeker has a reputation beyond reputeSummitseeker has a reputation beyond reputeSummitseeker has a reputation beyond reputeSummitseeker has a reputation beyond reputeSummitseeker has a reputation beyond reputeSummitseeker has a reputation beyond reputeSummitseeker has a reputation beyond reputeSummitseeker has a reputation beyond reputeSummitseeker has a reputation beyond repute
Default
This is the information from the servce manual:
Fault code No. 46 Symptom Power supply to the ECU is not normal.
Diagnostic code No. – –
Order Item/components and probable cause Check or maintenance job Reinstatementmethod
1 Connections
Wire harness ECU coupler
Check the coupler for any pins that may havepulled out.
Check the locking condition of the coupler.
If there is a malfunction, repair it and connect thecoupler securely.
Starting theengine andoperating it at idle.
2 Faulty battery. Replace or charge the battery.
Refer to “BATTERY INSPECTION” in CHAPTER 2.
3 Malfunction in rectifier/regulator. Replace if defective.
Refer to “CHARGING SYSTEM” in CHAPTER 8.
4 Open or short circuit in wire harness. Repair or replace if there is an open or short circuit.
Between the battery and main fuse.
Red – Red
Between the main fuse and ignition fuse.
Red – Red
Between the ignition fuse and main switch coupler.
Red/Yellow – Red/Yellow
Between the main switch coupler and engine stop
switch coupler.
Brown – Brown
Between the engine stop switch coupler and ECU
coupler.
Red/White – Red/White
  #4
Old 01-07-2011, 06:38 PM
reignman reignman is offline
Currently: Not set.
Basic Member
reignman has a brilliant futurereignman has a brilliant futurereignman has a brilliant futurereignman has a brilliant futurereignman has a brilliant futurereignman has a brilliant futurereignman has a brilliant futurereignman has a brilliant futurereignman has a brilliant futurereignman has a brilliant futurereignman has a brilliant future
Default
Was there water in the electrical connections? I have read where some sledders put electroless grease in all electrical connections to keep out the water. You stated that you were riding in deep snow, I wonder if excess snow entered the engine area and saturated the connections and caused electrical failure.
my 2 cents. rbb
  #5
Old 01-08-2011, 11:10 AM
Basic Member
Default DUNNO
NOT SURE ABOUT THE MOISTURE, THAT IS WHAT I AM THINKING. I HAVE PULLED ALL CONNECTIONS AND DRIED OUT, DIELECTIRIC GREASE, AND REASEMBLED. NEW STARTER, SOLENOID, + CABLE, STARTER WRAP ON THE STARTER, WHO KNOWS, I GUESS WE WILL TRY AGAIN.
  #6
Old 01-09-2011, 09:43 PM
graham_r graham_r is offline
Currently: Still Snowmobiling
graham_r has a reputation beyond reputegraham_r has a reputation beyond reputegraham_r has a reputation beyond reputegraham_r has a reputation beyond reputegraham_r has a reputation beyond reputegraham_r has a reputation beyond reputegraham_r has a reputation beyond reputegraham_r has a reputation beyond reputegraham_r has a reputation beyond reputegraham_r has a reputation beyond reputegraham_r has a reputation beyond repute
Default
Was talking to my dealer last month and he was saying he has seen the same thing. he said the realys fail
  #7
Old 01-11-2011, 01:17 PM
Basic Member
Default RELAY OR SOLENOID?
WAS IT THE RELAY OR SOLENOID THAT WAS FAILING?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — WTB helix tss 98 66/.46.46 or 68/.46.46 ER Thread Starter — river Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 4 Last Post — 02-14-2010 02:50 PM
Thread — Nytro Code 81 Thread Starter — Timberwolf1050 Forum — Nytros! Replies — 1 Last Post — 02-09-2010 08:03 PM
Thread — Apex Error Code 46 Thread Starter — Koby Forum — Yamaha: 4-Stroke Replies — 5 Last Post — 10-27-2009 11:16 AM
Thread — Nytro code problem... code 35... Thread Starter — Extreme-One Forum — Yamaha Replies — 4 Last Post — 01-02-2008 07:19 PM
