Upgrade to Premium
Ski-Doo: XP Sleds 2007.5-current, all models in the XP, XT and XR chassis
Reply
  #1
Old 12-21-2010, 01:28 PM
Skidoo83 Skidoo83 is offline
Currently: Not set.
Skidoo83 has a reputation beyond reputeSkidoo83 has a reputation beyond reputeSkidoo83 has a reputation beyond reputeSkidoo83 has a reputation beyond reputeSkidoo83 has a reputation beyond reputeSkidoo83 has a reputation beyond reputeSkidoo83 has a reputation beyond reputeSkidoo83 has a reputation beyond reputeSkidoo83 has a reputation beyond reputeSkidoo83 has a reputation beyond reputeSkidoo83 has a reputation beyond repute
Default how to adjust oil pump?
Is there any special tool required to adjust the oil pump and how do you adjust it. the sled needs more oil.
Rate this post: Yes | No
  #2
Old 12-21-2010, 06:28 PM
Ed Fast Ed Fast is offline
Currently: Wants to ride
Ed Fast has a reputation beyond reputeEd Fast has a reputation beyond reputeEd Fast has a reputation beyond reputeEd Fast has a reputation beyond reputeEd Fast has a reputation beyond reputeEd Fast has a reputation beyond reputeEd Fast has a reputation beyond reputeEd Fast has a reputation beyond reputeEd Fast has a reputation beyond reputeEd Fast has a reputation beyond reputeEd Fast has a reputation beyond repute
Default oil pump
I have a 08 not sure but would assume the same on the rest. You take the black guard off on the pipe side. Directly behind that there is some black wire wrap looking stuff tied to the engine with sip ties. Cut the ties and peel back the stuff( sorry spacing the name) and adjust the nut in there, You want to make it longer. I know this was a bad discription but I hope it helps.
Ed
  #3
Old 12-21-2010, 07:19 PM
powdersnobb powdersnobb is offline
Currently: Not set.
Basic Member
powdersnobb has a reputation beyond reputepowdersnobb has a reputation beyond reputepowdersnobb has a reputation beyond reputepowdersnobb has a reputation beyond reputepowdersnobb has a reputation beyond reputepowdersnobb has a reputation beyond reputepowdersnobb has a reputation beyond reputepowdersnobb has a reputation beyond reputepowdersnobb has a reputation beyond reputepowdersnobb has a reputation beyond reputepowdersnobb has a reputation beyond repute
Default
Just remove it and do premix! Do some searching on dootalk. It's the way to go. So far so good for me.
  #4
Old 12-22-2010, 12:51 AM
djnatzz djnatzz is online now
Currently: Not set.
Basic Member
djnatzz is an unknown quantity at this point
Default
hate to sound like a retard but.. how would you be able to tell if it needed more oil?
  #5
Old 12-22-2010, 02:24 AM
tpollon2 tpollon2 is offline
Currently: Recovering from shoulder surgery
tpollon2 has a reputation beyond reputetpollon2 has a reputation beyond reputetpollon2 has a reputation beyond reputetpollon2 has a reputation beyond reputetpollon2 has a reputation beyond reputetpollon2 has a reputation beyond reputetpollon2 has a reputation beyond reputetpollon2 has a reputation beyond reputetpollon2 has a reputation beyond reputetpollon2 has a reputation beyond reputetpollon2 has a reputation beyond repute
Default
Fill gas tank to the top, burp it and top it off. Mark your oil level before you ride. After ride measure how much oil you use to fill it back up to that mark. Fill your sled up with gas back to full, burp it and fill it some more to top it off at the gas staion. You will now have your fuel to oil ratio. It should be somewhere around 35 to 1 to be safe. Some guys lean it out to 40 to 1.
  #6
Old 12-22-2010, 01:51 PM
8alltheway 8alltheway is offline
Currently: Not set.
8alltheway has a reputation beyond repute8alltheway has a reputation beyond repute8alltheway has a reputation beyond repute8alltheway has a reputation beyond repute8alltheway has a reputation beyond repute8alltheway has a reputation beyond repute8alltheway has a reputation beyond repute8alltheway has a reputation beyond repute8alltheway has a reputation beyond repute8alltheway has a reputation beyond repute8alltheway has a reputation beyond repute
Default
any idea what they're set at from the dealer? My 09 seems to drink a hell of alot of oil. I was gonna lean it out to save a few bucks on oil but since my motor warranty expired I mite think better of that idea and just leave it
  #7
Old 12-22-2010, 01:59 PM
ak ak is online now
Currently: Nothing
ak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond repute
Default
16.5 mm is the measurment you want. That is ski doo spec.
  #8
Old 12-23-2010, 12:02 PM
snopro59 snopro59 is offline
Currently: Not set.
snopro59 has a reputation beyond reputesnopro59 has a reputation beyond reputesnopro59 has a reputation beyond reputesnopro59 has a reputation beyond reputesnopro59 has a reputation beyond reputesnopro59 has a reputation beyond reputesnopro59 has a reputation beyond reputesnopro59 has a reputation beyond reputesnopro59 has a reputation beyond reputesnopro59 has a reputation beyond reputesnopro59 has a reputation beyond repute
Default
Quote:
I have the manual and have mine set at 16.5 mm. It still is rich on oil and I would like to turn it down slightly.
Would I make it 17 mm or 16mm to lean the oil mixture?. The book doesn't talk about how lengthening or shortening effects the mixture. I don't want to go the wrong way.
  #9
Old 12-23-2010, 01:00 PM
ak ak is online now
Currently: Nothing
Default
the longer the measurement the less oil. The 600 sdi were set at 20 mm.
  #10
Old 12-23-2010, 02:31 PM
Hiterhard Hiterhard is offline
Currently: Not set.
Hiterhard has a reputation beyond reputeHiterhard has a reputation beyond reputeHiterhard has a reputation beyond reputeHiterhard has a reputation beyond reputeHiterhard has a reputation beyond reputeHiterhard has a reputation beyond reputeHiterhard has a reputation beyond reputeHiterhard has a reputation beyond reputeHiterhard has a reputation beyond reputeHiterhard has a reputation beyond reputeHiterhard has a reputation beyond repute
  #11
Old 12-23-2010, 03:36 PM
cjgodden cjgodden is offline
Currently: fixin broken chit
cjgodden has a reputation beyond reputecjgodden has a reputation beyond reputecjgodden has a reputation beyond reputecjgodden has a reputation beyond reputecjgodden has a reputation beyond reputecjgodden has a reputation beyond reputecjgodden has a reputation beyond reputecjgodden has a reputation beyond reputecjgodden has a reputation beyond reputecjgodden has a reputation beyond reputecjgodden has a reputation beyond repute
Garage
Click Here to Register
  #12
Old 12-28-2010, 06:31 PM
dooitinthesnow dooitinthesnow is offline
Currently: Not set.
dooitinthesnow has a reputation beyond reputedooitinthesnow has a reputation beyond reputedooitinthesnow has a reputation beyond reputedooitinthesnow has a reputation beyond reputedooitinthesnow has a reputation beyond reputedooitinthesnow has a reputation beyond reputedooitinthesnow has a reputation beyond reputedooitinthesnow has a reputation beyond reputedooitinthesnow has a reputation beyond reputedooitinthesnow has a reputation beyond reputedooitinthesnow has a reputation beyond repute
  #13
Old 12-30-2010, 06:57 AM
giddyup giddyup is online now
Currently: Not set.
giddyup has a reputation beyond reputegiddyup has a reputation beyond reputegiddyup has a reputation beyond reputegiddyup has a reputation beyond reputegiddyup has a reputation beyond reputegiddyup has a reputation beyond reputegiddyup has a reputation beyond reputegiddyup has a reputation beyond reputegiddyup has a reputation beyond reputegiddyup has a reputation beyond reputegiddyup has a reputation beyond repute
  #14
Old 12-30-2010, 09:39 AM
SWEETXPBEATCH SWEETXPBEATCH is offline
Currently: SHR 2013 SKi Doo XM
Basic Member
SWEETXPBEATCH has a reputation beyond reputeSWEETXPBEATCH has a reputation beyond reputeSWEETXPBEATCH has a reputation beyond reputeSWEETXPBEATCH has a reputation beyond reputeSWEETXPBEATCH has a reputation beyond reputeSWEETXPBEATCH has a reputation beyond reputeSWEETXPBEATCH has a reputation beyond reputeSWEETXPBEATCH has a reputation beyond reputeSWEETXPBEATCH has a reputation beyond reputeSWEETXPBEATCH has a reputation beyond reputeSWEETXPBEATCH has a reputation beyond repute
  #15
Old 12-30-2010, 04:55 PM
pyxle pyxle is offline
Currently: Concentrating on growing my beard
pyxle has a reputation beyond reputepyxle has a reputation beyond reputepyxle has a reputation beyond reputepyxle has a reputation beyond reputepyxle has a reputation beyond reputepyxle has a reputation beyond reputepyxle has a reputation beyond reputepyxle has a reputation beyond reputepyxle has a reputation beyond reputepyxle has a reputation beyond reputepyxle has a reputation beyond repute
The Following 5 Users Say Thank You to pyxle For This Useful Post:
fredw (02-22-2012), High Voltage (01-01-2011), Skidoo83 (01-03-2011), Spike38 (03-03-2011), SWEETXPBEATCH (12-30-2010)
  #16
Old 02-22-2012, 02:59 AM
fredw fredw is online now
Currently: now to dial it in on nitrous
Basic Member
fredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond repute
  #17
Old 02-23-2012, 01:25 AM
gman086's Avatar
gman086 gman086 is offline
Currently: Killing IT!
gman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond repute
  #18
Old 02-24-2012, 01:15 PM
Basic Member
  #19
Old 02-24-2012, 04:15 PM
evaldave evaldave is offline
Currently: waiting for snow
Basic Member
evaldave has a reputation beyond reputeevaldave has a reputation beyond reputeevaldave has a reputation beyond reputeevaldave has a reputation beyond reputeevaldave has a reputation beyond reputeevaldave has a reputation beyond reputeevaldave has a reputation beyond reputeevaldave has a reputation beyond reputeevaldave has a reputation beyond reputeevaldave has a reputation beyond reputeevaldave has a reputation beyond repute
  #20
Old 02-25-2012, 01:02 PM
gman086's Avatar
The Following User Says Thank You to gman086 For This Useful Post:
evaldave (02-25-2012)
  #21
Old 02-27-2012, 12:48 AM
morganotley morganotley is offline
Currently: Not set.
Basic Member
morganotley is an unknown quantity at this point
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — How do you adjust oil pump on 700MM? Thread Starter — Ford428CJ Forum — Yamaha: 2-stroke Replies — 7 Last Post — 12-20-2010 12:23 PM
Thread — Oil pump adjust info needed Thread Starter — 2DaMax Forum — Polaris: GEN 2 Replies — 13 Last Post — 11-10-2009 08:09 PM
Thread — Adjust throttle/oil pump cable on 2008 700RMK Thread Starter — ttyR2 Forum — Polaris Replies — 11 Last Post — 01-14-2009 01:27 AM
Thread — m7 oiler pump adjust. Thread Starter — Mtn. missle Forum — Arctic Cat Replies — 3 Last Post — 02-16-2008 08:50 PM
Thread — Oil pump adjust question and guard for the intake near the windshiled on an M series Thread Starter — depsnolvr Forum — Arctic Cat: M Series Replies — 7 Last Post — 02-10-2008 08:16 PM
