Upgrade to Premium
Polaris: 900 05-06 Polaris RMK 900
Reply
  #1
Old 12-13-2010, 05:41 PM
letsgosleddin letsgosleddin is offline
Currently: Indian Snow Dance Time
Basic Member
letsgosleddin is an unknown quantity at this point
Default Air Bleeding
I am about to put my oil tank back in and hook up fuel lines..My question is do I have to do anything to my fuel lines before I try and start it and how do I bleed the air out of oil line before I start it.
Oh and still curious if I can turn my track around and run it in the opposite direction..
Rate this post: Yes | No
  #2
Old 12-13-2010, 07:38 PM
guidoxpress's Avatar
guidoxpress guidoxpress is online now
Currently: Waiting to rip the Alaska snow!!!!!
guidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond repute
Garage
Default
1. you can prime your fuel lines and pump, but if ou dont know how just pull it over a few times to charge the capacitor and it will self prime, but may take a few pulls..
2. YES you need to bleed your oil line...did you crack the bleed screw on the front of the pump? you should...let the air bubbles come out there, AND i also wrap a piece of stiff wire on the pump lever and route it to the clutch area...when the sled starts, pull the wire and it will engage the oil pump to max and bleed the air that was as well....only let the sled idle when you do this, and do it for around 20 seconds...it will smoke cause your buring more oil but always safe...then after its bleed un hook the wire and your good...
you can also add 16oz of oil to your fuel tank of gas to ensure the air is all out when your riding...
3. if you messed with your coolant at all, make sure you bleed that as well with the front of the sled up high and crack the thermostat bleeder for a while off an don..
4. as for the track going backwards..i would say its no good...would defeat the purpose of the rotational design and ability to hook up
__________________
"Too much, is not enough"
2016 Polaris AXYS RMK 800 163
06 RMK 900
05 RMK 900
05 RMK 900
The Following 2 Users Say Thank You to guidoxpress For This Useful Post:
letsgosleddin (12-13-2010), sw (12-14-2010)
  #3
Old 12-13-2010, 08:07 PM
Basic Member
Default
I havnt started any of the process yet but this will def help out. And yes i did mess with the cooland. I pulled the radiator so I am glad you mentioned the air bleeding for that also. Cant wait to get after it this week. Been in Virginia going to school for 2 months.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Bleeding Brakes Thread Starter — Brett Slagle Forum — General Snowmobiling Replies — 7 Last Post — 10-08-2009 12:19 AM
Thread — Bleeding brakes m8? Help! Thread Starter — cat rider Forum — Arctic Cat: M Series Replies — 3 Last Post — 09-07-2009 06:19 PM
Thread — Tricks for bleeding air out of the oil line???? Thread Starter — summitX Forum — Ski-Doo Replies — 2 Last Post — 01-28-2009 03:38 PM
Thread — Bleeding brakes Thread Starter — goforbroke Forum — Ski-Doo Replies — 1 Last Post — 12-19-2008 05:51 PM
Thread — bleeding air out of oil lines on 900 rmk Thread Starter — cranktwister Forum — Polaris Replies — 3 Last Post — 09-01-2008 01:39 PM
