Upgrade to Premium
Yamaha: Boosted Sleds (Turbo or Supercharged) Turbo discussion for Yamaha aftermarket Turbo or Super Charged sleds.
Reply
  #1
Old 12-09-2010, 08:29 PM
tylerearl88 tylerearl88 is offline
Currently: Not set.
Basic Member
tylerearl88 is an unknown quantity at this point
Default Code 43 08 nytro
What does code 43 mean? Sled was running then I adjusted the co's and it wouldn't start. Put them back to 0 and it is flashing code 43 and check engine. Still won't start just cranks
Rate this post: Yes | No
  #2
Old 12-09-2010, 09:33 PM
Mountaintech's Avatar
Mountaintech Mountaintech is offline
Currently: Designing parts
Mountaintech has a reputation beyond reputeMountaintech has a reputation beyond reputeMountaintech has a reputation beyond reputeMountaintech has a reputation beyond reputeMountaintech has a reputation beyond reputeMountaintech has a reputation beyond reputeMountaintech has a reputation beyond reputeMountaintech has a reputation beyond reputeMountaintech has a reputation beyond reputeMountaintech has a reputation beyond reputeMountaintech has a reputation beyond repute
Default
Code 43- Power supply to the fuel injectors and fuel pump is not normal......Probable cause of malfunction......open or short circuit in wiring harness, or malfunction in ECU. Page 7-10 in manual. Diagnostics are on page 7-22.
__________________
www.mountaintechindustries.com Parts for Nytros
Formerly Roest
  #3
Old 12-10-2010, 07:44 AM
Currently: Not set.
Basic Member
Default
Thanks figured it out now. I dont have a manual. Does anyone know the compression my sled should have with the .063 head shim?
Thanks
  #4
Old 12-10-2010, 11:12 AM
Default
This is the ticket. You can buy manuals on CD as well, but I like them in hard copy. What did the problem end up being?
http://cgi.ebay.com/2008-Genuine-Yam...1#ht_500wt_951
__________________
Formerly Roest
  #5
Old 01-01-2011, 05:15 PM
starfire99 starfire99 is offline
Currently: Not set.
Basic Member
starfire99 has a reputation beyond reputestarfire99 has a reputation beyond reputestarfire99 has a reputation beyond reputestarfire99 has a reputation beyond reputestarfire99 has a reputation beyond reputestarfire99 has a reputation beyond reputestarfire99 has a reputation beyond reputestarfire99 has a reputation beyond reputestarfire99 has a reputation beyond reputestarfire99 has a reputation beyond reputestarfire99 has a reputation beyond repute
Default
Take the fuel pump relay out......warm it up so the grease inside softens, re-install it and your sled will start. This doesn't fix the problem, but when its -30 and you're 10 miles from home like we were, it'll get you home.
  #6
Old 02-06-2011, 11:12 PM
Summitseeker's Avatar
Summitseeker Summitseeker is online now
Currently: thinking about snow
Summitseeker has a reputation beyond reputeSummitseeker has a reputation beyond reputeSummitseeker has a reputation beyond reputeSummitseeker has a reputation beyond reputeSummitseeker has a reputation beyond reputeSummitseeker has a reputation beyond reputeSummitseeker has a reputation beyond reputeSummitseeker has a reputation beyond reputeSummitseeker has a reputation beyond reputeSummitseeker has a reputation beyond reputeSummitseeker has a reputation beyond repute
Default
I got this code today on my Nytro....I changed the relays but still nothing so I ran a wire from the positive on the battery to the positive terminal on the fuel pump just to get me out. Hopefully will get a chance to diagnose the problem this week. I am sure it is something simple!!
  #7
Old 02-07-2011, 06:21 AM
Northernboy Northernboy is offline
Currently: Gettin High on Boost!!!!
Northernboy has a reputation beyond reputeNorthernboy has a reputation beyond reputeNorthernboy has a reputation beyond reputeNorthernboy has a reputation beyond reputeNorthernboy has a reputation beyond reputeNorthernboy has a reputation beyond reputeNorthernboy has a reputation beyond reputeNorthernboy has a reputation beyond reputeNorthernboy has a reputation beyond reputeNorthernboy has a reputation beyond reputeNorthernboy has a reputation beyond repute
Default
Yamaha came out with a new fuel pump relay this year, P/N 8HG-81951-00-00. I replaced mine and it has not acted up since, but now my load relay is sticking when it is cold so I might upgrade it too.
  #8
Old 02-11-2011, 09:20 PM
phazerman2000 phazerman2000 is offline
Currently: Not set.
Basic Member
phazerman2000 is an unknown quantity at this point
Default
It is not grease that makes the relay stick. When the relay gets warm then cools off to super cold temps (10 below f or so), a layer of frost forms on the relays that are contaminated with internal moisture. That insulates the contact points in the relay and prevents current from flowing to the fuel pump and injectors. Warming the relay up by putting your hand on it or turning the key on and off several times should break through the frost and make contact! Get a new relay when you can!!!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — code 43 Thread Starter — snowriderz Forum — Yamaha: 4-Stroke Replies — 1 Last Post — 11-06-2009 05:31 AM
Thread — code 43 Thread Starter — snowriderz Forum — Yamaha Replies — 4 Last Post — 03-07-2009 05:50 PM
Thread — Code 43 on turbo phazer Thread Starter — letsgetrad Forum — Phazers! Replies — 1 Last Post — 02-23-2009 12:07 AM
Thread — code 43 on nytro Thread Starter — dexter Forum — Yamaha Replies — 4 Last Post — 01-26-2009 07:29 PM
Thread — code 43 Thread Starter — whatryan Forum — Yamaha Replies — 2 Last Post — 12-13-2008 11:20 AM
