Upgrade to Premium
Ski-Doo: S-2000 and older 1998 and older, all models in the S-2000 chassis and older chassis models
Reply
  #1
Old 12-01-2010, 09:54 PM
polarisdoo polarisdoo is offline
Currently: is wishing for a thick blanket of snow
Basic Member
polarisdoo is an unknown quantity at this point
Default 96 Formula Z 583 Bar riser issue
so after installing my new 4" riser on my formula, if i turn it sharp left, RPMs go up! not gonna lie i about pooped myself when i went sliding across the garage and hit the wall! haha it seems that the cables are just a tiny bit tight, can i just screw the adjustments on the cables where they go into the carbs and just loosen them up a bit, they are nearly all the way screwed out right now, the sled has nearly 6k miles on it and im sure the cables have stretched but i was wondering if i would have the room to gain?
let me know what you guys think!!!
thanks
Rate this post: Yes | No
  #2
Old 01-24-2011, 10:15 AM
fireball 440 fireball 440 is offline
Currently: Not set.
Basic Member
fireball 440 is an unknown quantity at this point
Default
I had a similar sled and 3" was as far as it'd go, and even with that the wires for the hand warmers are stetched to the max. To use your 4" you will need throttle cable extensions, or longer cables.
YAY! My first post on this site is actually useful!
Reply
Bookmarks
Tags
bar riser, formula z, throttle cable
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Pilot 5.9 skis on a 99 Formula Deluxe 583 Thread Starter — Do-The-Doo Forum — Ski-Doo: S-2000 and older Replies — 2 Last Post — 12-31-2011 10:06 AM
Thread — 1994 Skidoo Formula STX 583 Thread Starter — Rat Fink Forum — Ski-Doo (Swapmeet) Replies — 3 Last Post — 12-08-2009 12:23 AM
Thread — 96 formula 500 turbo in a/b Thread Starter — dagwood Forum — Ski-Doo (Swapmeet) Replies — 2 Last Post — 04-27-2009 08:19 AM
Thread — 95 Formula Z 583.!!!NEED TO SELL Thread Starter — tolleysummitx Forum — Ski-Doo (Swapmeet) Replies — 2 Last Post — 02-16-2008 12:29 PM
Thread — 1994 skidoo Formula Z 583 Thread Starter — brnr17 Forum — Ski-Doo (Swapmeet) Replies — 1 Last Post — 12-16-2007 12:39 PM
