Upgrade to Premium
Ski-Doo: S-2000 and older 1998 and older, all models in the S-2000 chassis and older chassis models
Reply
  #1
Old 01-11-2010, 09:57 PM
Pirateracingcustoms Pirateracingcustoms is offline
Currently: Not set.
Basic Member
Pirateracingcustoms is an unknown quantity at this point
Unhappy 1998 doo mach 1 700 wiring harness cross over
Wondering if anybody knows if the wiring harness for a 98 formula 700 will work on a 98 mach1 700. I cant find a web site with part numbers to compare so I thought I would check you guys. Im not really conerned with the hood harness but everything from the hood to the tank melted (fuel fire) Thanks guys!
Rate this post: Yes | No
  #2
Old 01-12-2010, 03:20 AM
Alaskanbulldogs Alaskanbulldogs is offline
Currently: Not set.
Basic Member
Alaskanbulldogs is an unknown quantity at this point
Default
the harness will be the same.Be shure to look for bare wires and add loom before install!! The cdi will be different however.
  #3
Old 01-12-2010, 09:11 AM
Currently: Not set.
Basic Member
Default
cool thanks!! I dont think I will be getting the cdi any how.
  #4
Old 01-12-2010, 10:13 AM
Zachmandu Zachmandu is offline
Currently: Not set.
Basic Member
Zachmandu has a reputation beyond reputeZachmandu has a reputation beyond reputeZachmandu has a reputation beyond reputeZachmandu has a reputation beyond reputeZachmandu has a reputation beyond reputeZachmandu has a reputation beyond reputeZachmandu has a reputation beyond reputeZachmandu has a reputation beyond reputeZachmandu has a reputation beyond reputeZachmandu has a reputation beyond reputeZachmandu has a reputation beyond repute
Default
I shoulda chimed in yesterday...
My experience is with S-chassis sleds... but from what I have seen, 'Doo pretty much used the same harness regardless of model. Only differences i have seen from sled to sled seems to be if the sled had DPM or not. Harnesses for those sleds ARE different. But if it is just your run-of-the-mill ignition system, they are all the same.
I would think that the CK3 would be similar....
  #5
Old 01-12-2010, 01:31 PM
Currently: Not set.
Basic Member
Default
The f111 700 and mach1 are both ck111 chassis and they all came from the factory with harness issues,where the harness runs under the engine it only had one layer of elec. tape wraped around it.The harness rubs on the floor of the b.h. and shorts,giving lighting and ignition problems.To fix add loom.
  #6
Old 01-12-2010, 06:59 PM
Currently: Not set.
Basic Member
Default
what is DPM? Im new to sleds and skidoo so I really dont know the differences between models. My issue is my sled caught fire but, I fully intend on looming the crap out of it and Im even going to use the heat resistant stuff where heat could be an issue. Putting that silver stuff on my fuel lines too! Is the ignition box under the engine? I saw a box under there but I havnt pulled the engine yet. If it is Im sure its toast as well.
  #7
Old 01-12-2010, 07:55 PM
Currently: Not set.
Basic Member
Default
The cdi is located under the engine and is programed to the teather. The 98 f111 and mach 1 are the same machine for the most part. You will need to buy a cdi for a mach 1 however.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
