Upgrade to Premium
Polaris: 900 05-06 Polaris RMK 900
Reply
  #1
Old 01-04-2010, 10:43 PM
guidoxpress's Avatar
guidoxpress guidoxpress is offline
Currently: Waiting to rip the Alaska snow!!!!!
guidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond repute
Garage
Default My Wifes 06 RMK 700 Build!
Since I have a Build (in my sig) of my RMK 900 , my wife wanted to get a thread of her sled to show everyone...
Its been a GREAT sled..NOT a single issue with the sled i have had in 2 years..except for those that i have caused..
--i ramped it off the tilt trailer on the roof of my truck and it landed upside down on the ground
--busted both front motor mount bolts in the engine due to my stupidity
--every time i break something on my sled, i part out hers
Overall, it is an absolutely GREAT SLED..the power is excellent, and she can smoke most 700s and some 800s out there.... its very reliable, and has ever mod to make it last even longer...
Here is my list of parts on the sled..and where you can find them if you are interested..if they are not OEM parts!
Venting
•MoFlow Dash Vent Kit (www.Moflowvents.com)
•Mountain Fit Hoods, Side Panel Vent kit (http://stores.homestead.com/williammoore/StoreFront.bok)
•Mountain Fit Hoods, Shock Vent kit (http://stores.homestead.com/williammoore/StoreFront.bok)
•LongTracksEdge Lower Side Panel Vents
BODY
•SPG Seat Post (www.sledsolutions.com)
•RED Powder Coated 09 Front Bumper (done by myslef)
•09 IQ Front End Conversion (www.FTXMotorsports.com)
•09 OEM Skid Plate
•Black Powder Coated Engine Support Braces (done by myself)
•RED Powder Coated Recoil Housing (done by myself)
•Black Powder Coated Better Boards (www.snowmobilebetterboards.com)
•BLACK w/Flame IQ Windscreen
•RED Polaris handguards with OEM mounts
•Fastlane Hood Strap Kit (www.Flaneinc.com)
•Pro-Armor Tether Cord
•Dzus Fastner Kit for Side Panels
•Billet Pull Handle (www.Ebay.com)
•Gripper Skis
•HOLZ Gas Rack
•PowerMadd Extended Brake Lever (http://www.parkeryamaha.com/powermad...orpolaris.aspx)
•Polaris Underseat Bag
•Skinz Knee Console Pads (www.skinzprotectivegear.com)
•IQ Center Fog Light Beam
Engine
•Custom 06 RED Billet Chaincase Cover (Polzinhunter on forum)
•’06 Rear Motor Mounts
•CompFusion Front Motor Mounts (CompFusion on forum)
•SLP Push Arm (www.startinglineproducts.com)
•SLP Torque Arm (www.startinglineproducts.com)
•06 SLP Pipe (www.startinglineproducts.com)
•06 SLP Y-Pipe (www.startinglineproducts.com)
•MBRP Racing Stinger Can (www.MBRP.com)
•FBF Throttle/Oiler Cable (FatBoyzFrenchy on forum)
•BoonDockers Control Box (www.Boondockers.com)
•HYVO 19/42 Gears
•Royal Purple ATF Chaincase Fluid
•Updated TPS Wiring Harness
•Armor Cord Heavy Duty Pull Rope (www.Armorcord.com)
•FNI Intake (www. Firenice.us)
•RED Powder Coated Belt Cover (done by myself)
•Electric Start Kit (needs installed)
Suspension
•Fox Floats Front Shocks (www.Foxracingshox.com)
•BLACK Fox Float Roost Guards (www.Foxracingshox.com)
•RYDE FX Rear Track Shock
•RYDE FX Front Track Shock
•225lb Front Track Spring
•MMP Freedom Axle (www.Mountainmachines.us)
•MountainAddiction 8” Billet Big Wheel Kit (www.MountainAddiction.com)
•HOLZ 41” Wide A-Arms (www.Holzracingproducts.com)
•HOLZ Black Billet Spindles (www.Holzracingproducts.com)
•HOLZ Billet Tie-Rods
•Polaris Billet Rail Brace
•07-up IQ Steering Boot Covers
•Ice Scratchers (SummitSeeker on forum)
•159” Series IV Track 2.4” Paddles
Clutching
•Team TSS-98 Secondary
•64/42.46 Twin Trax Helix
•2 Derlin Washers in Secondary
•Black/Red or Red/Pink Secondary Spring
•3211115 Drive Belt
•Balanced P-85 Drive Clutch
•10-68g MTX Weights
•Black/Green Primary Spring
•RED Powder Coated Primary Cover (done by myself)
•RED Powder Coated Secondary Cover (done by myself)
MISC
•Warm-up Stand (www.Easymovecarts.com)
•EZ Sled Lift (www.Easymovecarts.com)
•SLP Clutch Press Tool for Primary/Secondary (www.startinglineproducts.com)
•SLP Clutch Holding Tool (www.startinglineproducts.com)
Wish List
•Custom UHMW Side Panel “RMK 700” (Polzinhunter on forum)
•AMP Billet Gas Cap
•Billet Idler Wheels
•09 sway bar setup
•ZBROZ sway bar bracket for 09 sway bar
•SLP Cylinder Porting with Decompression Hole Plugging
•2poor Rear Motor Mounts, Torque Arm Assembly
•Timbersled sway bar block off plate
•Anti-Stab Kit
•Anti-Rachet Drivers
•Fully Clipped Track
•Heavy Duty Torsion Springs .377/47 degree
•Rebuilt Stator
•Updated 32mm Crankshaft
•Torque Master I Crank Modification
•Black Powder Coated Skid
•SPG RED Powder Coated Rear Bumper
•Innovative AF Gauge
__________________
"Too much, is not enough"
2016 Polaris AXYS RMK 800 163
06 RMK 900
05 RMK 900
05 RMK 900
Rate this post: Yes | No
The Following User Says Thank You to guidoxpress For This Useful Post:
94fordguy (01-04-2010)
  #2
Old 01-04-2010, 10:44 PM
Garage
Default
__________________
06 RMK 900
05 RMK 900
05 RMK 900
  #3
Old 01-04-2010, 10:45 PM
BIGGDAWG BIGGDAWG is offline
Currently: Not set.
BIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond repute
Garage
Default
nice looking ride she has there
  #4
Old 01-04-2010, 10:47 PM
Garage
Default
__________________
06 RMK 900
05 RMK 900
05 RMK 900
The Following 2 Users Say Thank You to guidoxpress For This Useful Post:
94fordguy (01-04-2010), WHEREDAFUGAWEE (01-05-2010)
  #5
Old 01-04-2010, 10:56 PM
Garage
Default
Quote:
it WAS..until i yank the shocks off
thanks Bruce...she talks smack on me buying so much, then once its installed..and somone sees her riding it..she braggs non-stop how sick/setup her sled is, lol...
plus she looks FINE riding it
__________________
06 RMK 900
05 RMK 900
05 RMK 900
  #6
Old 01-04-2010, 11:14 PM
rmk2112's Avatar
rmk2112 rmk2112 is offline
Currently: sled search mode.....
Basic Member
rmk2112 has a reputation beyond reputermk2112 has a reputation beyond reputermk2112 has a reputation beyond reputermk2112 has a reputation beyond reputermk2112 has a reputation beyond reputermk2112 has a reputation beyond reputermk2112 has a reputation beyond reputermk2112 has a reputation beyond reputermk2112 has a reputation beyond reputermk2112 has a reputation beyond reputermk2112 has a reputation beyond repute
Garage
Default
Quote:
Just remember to leave the NOTE!!
Nice looking sled............Love the Holz Front end. I'm going to put the side panel vents on mine soon too. Looks great!!
__________________
Member: SAWS - WSSA - BRC
The Following User Says Thank You to rmk2112 For This Useful Post:
guidoxpress (01-04-2010)
  #7
Old 01-04-2010, 11:37 PM
94fordguy's Avatar
94fordguy 94fordguy is offline
Currently: Riding!
94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute
Cool
Awesome man... that's about all I can say... awesome!
Thanks for sharing Sean... very cool
Once again I feel my 900 is just so... stock
__________________
ARRA MEMBER - Americans for Responsible Recreational Access
WSSA MEMBER - Washington State Snowmobile Association
Yakima Ski Benders MEMBER - Washington's first snowmobile club
Support Public Access to Public Land
13 PRO RMK 800 162 VEI Custom
08 Polaris Scrambler 500 4x4
07 KTM 450 XCF
06 Kawasaki ZZR 600
06 Ford F-350 King Ranch C/C L/B 4x4 Powerstroke...118K
05 RMK 900 166 Anniversary Edition #850 6,050 Miles
02 Interstate 19' Enclosed
The Following User Says Thank You to 94fordguy For This Useful Post:
guidoxpress (01-05-2010)
  #8
Old 01-05-2010, 12:02 AM
Garage
Default
LOL...
seth..i am trying to make you feel bad...since you have all the snow this year i had to do something to bring you down from that high you were on..haha..
thanks alot for the comments..she really likes to hear compliments on her sled...
__________________
06 RMK 900
05 RMK 900
05 RMK 900
  #9
Old 01-05-2010, 01:02 AM
rideharder rideharder is offline
Currently: anyone have a spare job?
Basic Member
rideharder is an unknown quantity at this point
Default
still love the look of the iqr mod hood but that 700 is Killer..... just needs a 9 top end
The Following User Says Thank You to rideharder For This Useful Post:
  #10
Old 01-05-2010, 01:10 AM
WHEREDAFUGAWEE WHEREDAFUGAWEE is offline
Currently: Time to put away the Harley and get the sledout
Basic Member
WHEREDAFUGAWEE has a reputation beyond reputeWHEREDAFUGAWEE has a reputation beyond reputeWHEREDAFUGAWEE has a reputation beyond reputeWHEREDAFUGAWEE has a reputation beyond reputeWHEREDAFUGAWEE has a reputation beyond reputeWHEREDAFUGAWEE has a reputation beyond reputeWHEREDAFUGAWEE has a reputation beyond reputeWHEREDAFUGAWEE has a reputation beyond reputeWHEREDAFUGAWEE has a reputation beyond reputeWHEREDAFUGAWEE has a reputation beyond reputeWHEREDAFUGAWEE has a reputation beyond repute
The Following User Says Thank You to WHEREDAFUGAWEE For This Useful Post:
  #11
Old 01-05-2010, 08:51 AM
Danbot Danbot is offline
Currently: bustin' pow
Danbot has a reputation beyond reputeDanbot has a reputation beyond reputeDanbot has a reputation beyond reputeDanbot has a reputation beyond reputeDanbot has a reputation beyond reputeDanbot has a reputation beyond reputeDanbot has a reputation beyond reputeDanbot has a reputation beyond reputeDanbot has a reputation beyond reputeDanbot has a reputation beyond reputeDanbot has a reputation beyond repute
Garage
Click Here to Register
The Following User Says Thank You to Danbot For This Useful Post:
  #12
Old 01-05-2010, 11:24 AM
Garage
  #13
Old 01-05-2010, 12:57 PM
MARV1's Avatar
MARV1 MARV1 is offline
Currently: On top of Moron Mtn. . .
MARV1 has a reputation beyond reputeMARV1 has a reputation beyond reputeMARV1 has a reputation beyond reputeMARV1 has a reputation beyond reputeMARV1 has a reputation beyond reputeMARV1 has a reputation beyond reputeMARV1 has a reputation beyond reputeMARV1 has a reputation beyond reputeMARV1 has a reputation beyond reputeMARV1 has a reputation beyond reputeMARV1 has a reputation beyond repute
The Following User Says Thank You to MARV1 For This Useful Post:
  #14
Old 01-05-2010, 01:12 PM
triple650 triple650 is offline
Currently: Not set.
triple650 has a reputation beyond reputetriple650 has a reputation beyond reputetriple650 has a reputation beyond reputetriple650 has a reputation beyond reputetriple650 has a reputation beyond reputetriple650 has a reputation beyond reputetriple650 has a reputation beyond reputetriple650 has a reputation beyond reputetriple650 has a reputation beyond reputetriple650 has a reputation beyond reputetriple650 has a reputation beyond repute
  #15
Old 01-05-2010, 01:19 PM
Garage
  #16
Garage
MARV1 (01-06-2010)
  #17
Old 01-05-2010, 01:41 PM
wasatchrider wasatchrider is offline
Currently: Not set.
Basic Member
wasatchrider has a reputation beyond reputewasatchrider has a reputation beyond reputewasatchrider has a reputation beyond reputewasatchrider has a reputation beyond reputewasatchrider has a reputation beyond reputewasatchrider has a reputation beyond reputewasatchrider has a reputation beyond reputewasatchrider has a reputation beyond reputewasatchrider has a reputation beyond reputewasatchrider has a reputation beyond reputewasatchrider has a reputation beyond repute
  #18
Old 01-05-2010, 01:44 PM
Currently: Not set.
Basic Member
  #19
Old 01-05-2010, 01:49 PM
Garage
  #20
Old 01-05-2010, 06:37 PM
NewfieBullet1973 NewfieBullet1973 is offline
Currently: Back After My Summer Hibernation!!!
NewfieBullet1973 has a reputation beyond reputeNewfieBullet1973 has a reputation beyond reputeNewfieBullet1973 has a reputation beyond reputeNewfieBullet1973 has a reputation beyond reputeNewfieBullet1973 has a reputation beyond reputeNewfieBullet1973 has a reputation beyond reputeNewfieBullet1973 has a reputation beyond reputeNewfieBullet1973 has a reputation beyond reputeNewfieBullet1973 has a reputation beyond reputeNewfieBullet1973 has a reputation beyond reputeNewfieBullet1973 has a reputation beyond repute
The Following User Says Thank You to NewfieBullet1973 For This Useful Post:
  #21
Old 01-05-2010, 07:30 PM
Garage
  #22
Old 01-05-2010, 09:46 PM
Sxrlar's Avatar
Sxrlar Sxrlar is online now
Currently: Thinking about snow
Sxrlar has a reputation beyond reputeSxrlar has a reputation beyond reputeSxrlar has a reputation beyond reputeSxrlar has a reputation beyond reputeSxrlar has a reputation beyond reputeSxrlar has a reputation beyond reputeSxrlar has a reputation beyond reputeSxrlar has a reputation beyond reputeSxrlar has a reputation beyond reputeSxrlar has a reputation beyond reputeSxrlar has a reputation beyond repute
The Following User Says Thank You to Sxrlar For This Useful Post:
  #23
Old 01-05-2010, 11:13 PM
Garage
  #24
Old 01-06-2010, 12:43 AM
MARV1's Avatar
guidoxpress (01-06-2010)
  #25
Old 03-11-2010, 12:44 AM
Garage
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
