Upgrade to Premium
Ski-Doo: REV Sleds 2004.5-200, all models in the REV chassis
Reply
  #1
Old 01-01-2010, 06:56 PM
Blake541 Blake541 is offline
Currently: Not set.
Blake541 is an unknown quantity at this point
Garage
Default Ski-Doo Electrical problems
SLEDDERS!!!
Well it's dumping snow in northern Utah, should be a good weekend!!! One dilemma though, I have a 2007 Ski-Doo summit 800 REV that won't run very good. It will run, but thats it, no electrical at all, no gauges, no reverse beep and i'm assuming the DPM is not running because the motor is running, but not well. I've heard the common problem is a bad relay, if this is what it is, does anyone have a part number for a relay?? It's just the Adrenaline model, 800r with a 151, stock sled for 07, no engine upgrades. Any help would be fantastic!
Thanks,
Blake
Rate this post: Yes | No
  #2
Old 01-01-2010, 07:01 PM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
Yep, sounds like the relay. Do a search on here or on dootalk and there are part numbers for several different common automotive relays that will work.....Not a bad idea to carry a spare.
  #3
Old 01-01-2010, 09:43 PM
chrispy chrispy is offline
Currently: Not set.
Basic Member
chrispy has a reputation beyond reputechrispy has a reputation beyond reputechrispy has a reputation beyond reputechrispy has a reputation beyond reputechrispy has a reputation beyond reputechrispy has a reputation beyond reputechrispy has a reputation beyond reputechrispy has a reputation beyond reputechrispy has a reputation beyond reputechrispy has a reputation beyond reputechrispy has a reputation beyond repute
Default
I've got a spare relay zip tied right next to the stock one in case one dies. Cheap insurance this problem won't leave me or the sled stranded in the bush for the night.
  #4
Old 01-01-2010, 10:17 PM
Van Epps Van Epps is offline
Currently: New pony in barn! Yee Haw
Basic Member
Van Epps has a reputation beyond reputeVan Epps has a reputation beyond reputeVan Epps has a reputation beyond reputeVan Epps has a reputation beyond reputeVan Epps has a reputation beyond reputeVan Epps has a reputation beyond reputeVan Epps has a reputation beyond reputeVan Epps has a reputation beyond reputeVan Epps has a reputation beyond reputeVan Epps has a reputation beyond reputeVan Epps has a reputation beyond repute
Default
Napa AR 143. at least thats the one for my 04 rev.
  #5
Old 01-02-2010, 06:07 PM
FNSheldon FNSheldon is offline
Currently: Not set.
Basic Member
FNSheldon is an unknown quantity at this point
Default
This is very common for these Rev's. They use a typical horn relay which you can buy at any automotive supply store for $7-14. Take your old one in and buy two. I also have a spare zip-tied to the working one, you will need it. The last one I bought was a BOSCH from NAPA and it looked a little more heavy duty and has not quit this year yet(knock on wood)
  #6
Old 01-02-2010, 08:49 PM
Mac-Daddy-Racing-212 Mac-Daddy-Racing-212 is offline
Currently: Itching to RIDE
Basic Member
Mac-Daddy-Racing-212 is an unknown quantity at this point
Default
I pulled mine and took it to NAPA. Got the heavy duty unit (higher amperage capability). Don't have the number, but the gal behind the counter knew what it was. Then I told her it came off of a snowmobile. She was shocked. no pun intented.
  #7
Old 01-03-2010, 12:40 PM
ski doo valmont ski doo valmont is offline
Currently: Not set.
Basic Member
ski doo valmont has a brilliant futureski doo valmont has a brilliant futureski doo valmont has a brilliant futureski doo valmont has a brilliant futureski doo valmont has a brilliant futureski doo valmont has a brilliant futureski doo valmont has a brilliant futureski doo valmont has a brilliant futureski doo valmont has a brilliant futureski doo valmont has a brilliant futureski doo valmont has a brilliant future
Default
Quote:
Does the Napa AR 143 relay fit a 07 800 r summit also????????
  #8
Old 01-06-2010, 09:11 PM
Basic Member
Default
Pull it off and take it in. Any auto parts place will have one. O'Riley Auto had one for the neighbors 06 600 HO today. He was in a panic after the ride. I said "no biggie, I can fix that". Took the spare out and fixed it in 5 mins. Beer is good tonight!!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
