Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 11-04-2009, 02:16 PM
Racinjason Racinjason is offline
Currently: Not set.
Basic Member
Racinjason is an unknown quantity at this point
Default Clutching & Gearing 1200 turbo
Can anyone help me clutch and gear this doo? I run the stock tra with cj motorsports turbo and clutch pinned,154 track. Right now I have 82.5 grams per arm, 414 ramps, 47/44 helix. I would like to use skidoo parts since i work for a skidoo dealer. Top gear is 23 and the bottom gear is stock
Rate this post: Yes | No
  #2
Old 11-11-2009, 12:48 PM
underboost underboost is offline
Currently: Not set.
Basic Member
underboost has a brilliant futureunderboost has a brilliant futureunderboost has a brilliant futureunderboost has a brilliant futureunderboost has a brilliant futureunderboost has a brilliant futureunderboost has a brilliant futureunderboost has a brilliant futureunderboost has a brilliant futureunderboost has a brilliant futureunderboost has a brilliant future
Default
go with shockwave adjustable helix and dalton pin. you need to add more weight in the primary and shallow angle in the secondary. this will considerably reduce, look remove, belt temp.
for sure, 47/44 cam is to steeper. you need to squeeze the belt more.
I ran a fpp kit last year on a gade....
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
