Upgrade to Premium
Ski-Doo: REV Sleds 2004.5-200, all models in the REV chassis
Reply
  #1
Old 10-28-2009, 12:35 AM
sleddr800 sleddr800 is offline
Currently: working in the forest
Basic Member
sleddr800 is an unknown quantity at this point
Default Nun replacement
I read on here a while back about some guys bolting the new nun on vs re-rivetting back on - in case it needs to be replaced again. Just wondering if anyone has done this and how well it worked?
Also wondering if one has to pull the motor entirely to remove the nun?
What would someone use to remove the stock steel rivets? Drilling them out hasn't gone well so far!!
Thanks.
Rate this post: Yes | No
  #2
Old 10-28-2009, 08:13 AM
skidoo_03 skidoo_03 is offline
Currently: a
Basic Member
skidoo_03 has a brilliant futureskidoo_03 has a brilliant futureskidoo_03 has a brilliant futureskidoo_03 has a brilliant futureskidoo_03 has a brilliant futureskidoo_03 has a brilliant futureskidoo_03 has a brilliant futureskidoo_03 has a brilliant futureskidoo_03 has a brilliant futureskidoo_03 has a brilliant futureskidoo_03 has a brilliant future
Default
My brothers was bolted back on when he replaced it last. it held up as good as the rivets. a little more time consuming to put it back together, but if you think you will have to replace again, might not be a bad idea. personally i dont think drilling the rivets is too bad (once they aren't the stock ones)
can't remember for sure, but dont think you have to remove engine.
to remove the steel rivets go buy a GOOD drill bit or two and go to town. they are a pain, but no other way to do it really. air chisel maybe would work. center punch the round headed ones helps too.
i think Skidoo has a bulletin on replacing the nun and what bolts and everything to use. I am at work right now, but will see if I have it on my comp at home when I get a chance.
  #3
Old 10-28-2009, 08:40 AM
Summit Guy Summit Guy is offline
Currently: Not set.
Summit Guy has a reputation beyond reputeSummit Guy has a reputation beyond reputeSummit Guy has a reputation beyond reputeSummit Guy has a reputation beyond reputeSummit Guy has a reputation beyond reputeSummit Guy has a reputation beyond reputeSummit Guy has a reputation beyond reputeSummit Guy has a reputation beyond reputeSummit Guy has a reputation beyond reputeSummit Guy has a reputation beyond reputeSummit Guy has a reputation beyond repute
Default
I have the ski-doo bulletin and it calls for bolting it in, I did it that way and it works well. If you would like the bulletin PM your email address.
  #4
Old 11-05-2009, 04:53 PM
Beels Beels is offline
Currently: There's NOTHING free or basic about me
Basic Member
Beels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond repute
Default
The race chassis Revs had the nun OEM bolted in.
Go with the bolts.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
