2001 Summit 700 - SnoWest Forum
SnoWest
FORUMS NEWS SNOWEST PERFORMANCE TRAVEL PHOTO VIDEO SUBSCRIBE
New Thread
Go Back   SnoWest Forum > SnowMobiles > Ski-Doo
Register Forums New Posts Classifieds Garages
Reply
Thread Tools Display Modes
  #1
Old 08-27-2009, 11:22 PM
digger18 digger18 is offline
Currently: Wishing I Lived Out West
Points: 12,428, Level: 26 Points: 12,428, Level: 26 Points: 12,428, Level: 26
Level up: 76% Level up: 76% Level up: 76%
Activity: 0% Activity: 0% Activity: 0%
digger18 has a reputation beyond reputedigger18 has a reputation beyond reputedigger18 has a reputation beyond reputedigger18 has a reputation beyond reputedigger18 has a reputation beyond reputedigger18 has a reputation beyond reputedigger18 has a reputation beyond reputedigger18 has a reputation beyond reputedigger18 has a reputation beyond reputedigger18 has a reputation beyond reputedigger18 has a reputation beyond repute
Default 2001 Summit 700
Buddy just picked up a 2001 700 Summit. Don't know to much about ski doos. Was wondering what the clutch setting should be at around here,MN? The right way to adjust them.Also what it should idle. How to adjust that to. Thanks
Rate this post: Yes | No
  #2
Old 08-28-2009, 02:20 AM
FNG's Avatar
FNG FNG is offline
Currently: Not set.
Points: 15,106, Level: 29 Points: 15,106, Level: 29 Points: 15,106, Level: 29
Level up: 66% Level up: 66% Level up: 66%
FNG has a reputation beyond reputeFNG has a reputation beyond reputeFNG has a reputation beyond reputeFNG has a reputation beyond reputeFNG has a reputation beyond reputeFNG has a reputation beyond reputeFNG has a reputation beyond reputeFNG has a reputation beyond reputeFNG has a reputation beyond reputeFNG has a reputation beyond reputeFNG has a reputation beyond repute
Default
Good sled.
Where in MN? ie, what altitude will your buddy be riding at.
I have an 01 Summit 700 standard and from what I've read it was set up (carbed) to run at altitude (6000 ft plus) so if you are anywhere at or above that you should be good with the standard jetting (pto and mag side 520 main jet and 17.5 pilot jet btw), shoulb be a pair of TM type carbs in there.
The Manual I have says warm idle at 1500 +/- 200. and it's probubly worth ordering a manual on disc, especially if your friend is mechanically inclined and on a budget, (do a search, or just buy one on e-bay for probubly $10.00-15.00).
If it's new to you (or your buddy) it is probubly worth taking the sled to some clutching guy and having them service the clutch(s), replace buttons, ect... as needed, just nice to have a good starting point and a clean clutch is a happy clutch, oh, change the chain case oil (again, just to have a starting point).
How many miles are on it, many of the Summits are due for a top end and probubly lubeing the bottum end crank bearings too by around 4000mi. Check the compression, 110 is getting worn and tired, soon to be rebuilt, 140's and you are golden
If you can shed the stock can for something after market then you can shed some weight easily and these sleds like that.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All contents copyright 2007-2010, SnoWest Magazine, Harris Publishing Inc.
SnoWest is published by Harris Publishing, Inc. Forums Directory
no new posts
