Upgrade to Premium
Reply
  #1
Old 04-13-2009, 11:15 PM
AMSOILR AMSOILR is offline
Currently: Go with the BEST!!!!!!!!!!!
AMSOILR has a reputation beyond reputeAMSOILR has a reputation beyond reputeAMSOILR has a reputation beyond reputeAMSOILR has a reputation beyond reputeAMSOILR has a reputation beyond reputeAMSOILR has a reputation beyond reputeAMSOILR has a reputation beyond reputeAMSOILR has a reputation beyond reputeAMSOILR has a reputation beyond reputeAMSOILR has a reputation beyond reputeAMSOILR has a reputation beyond repute
Default 08 800 XP Fuel gauge problem
What has been the problem with the XP fuel gauges? (Gauge, sender unit or fuse holder) Are they warrantied? Mine is not working at all. All I get is a low fuel light.
Rate this post: Yes | No
  #2
Old 04-14-2009, 01:06 AM
eddy's Avatar
eddy eddy is online now
Currently: Winter is here. Ride on!
eddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond repute
Default Gauge
Computer re-flash cures many issues.
  #3
Old 04-14-2009, 11:24 AM
Teth-Air's Avatar
Teth-Air Teth-Air is offline
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
Default
1 - if no work, replace fuse
2 - if work partly, try rotating sender incase it is stuck on tank wall
3 - if reflash has been done, don't expect it to ever go above 3/4 tank but seems to work okay from there down
To much hastle to go any farther for me/
__________________
Home of the "Cordless Teth-Air" and NEW "Phantom Teth-Air"
http://www.sourceinnovations.ca
We also have TKI Belt Drives, Arm Candy A-Arm Braces, Oil Tank Inserts, Reversible Scratchers, Cat Hood hooks, and more.
  #4
Old 03-31-2010, 05:19 PM
husadoo husadoo is offline
Currently: Not set.
Basic Member
husadoo is an unknown quantity at this point
Unhappy Fuel gauge and hot grip gauge not working
I have the same problem with my 08 XP 800X. The fuel or hot grip display is not present on the dash gauge. The dealer didn't seem to think a computer flash would fix it. I wish Ski Doo would have better customer service. May try other brand next time.
  #5
Old 03-31-2010, 06:38 PM
xpspenziv's Avatar
xpspenziv xpspenziv is offline
Currently: boooasting
xpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond repute
Default elec probs are time consuming
pull the hood off and take out the 5 screws that hold the headlight assembly and remove.there will be a BIG wire harness there (2).trace from the weather pack connector to the hand warmer switch and check for continuity from switch to weather pack conn(possably broke wire)same for the fuel gauge.
you can also trace to a relay or sending unit.
GROUNDS.shop manual is a great tool but not cheap,i got mine at I-90
fuel gauge)put a spare on the tunnel and dont worry about it,keep track of average miles before the sled runs out of gas 80-100.
dont forget to push the tunnel down when fueling it will give you3/4 to 1.3 gals more.
  #6
Old 04-01-2010, 08:26 AM
xpspenziv's Avatar
Default
Quote:
sounds like that dealer needs a attitude adjustment.
try re flash wont know if you dont try.ask the kid in the shop or desk if anyone there is familiar with the budds systems,if under warranty,i know some were replaced doo to similar probs,if re flashes didn't work they had to replace instrument cluster.
its the dealer not the manufacturer that is giving you greef.
  #7
Old 04-01-2010, 09:33 PM
Thumbs down Skidoo should be proud
I've been through all of the things listed above and the gauge is exactly as Teth-Air says, reads no more than 3/4 full. It's better but not right. Piss poor system, Skidoo should be proud.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
