B
brentsooley
New member
what is the stock gearing in a 05 900 RMK and what is the best gearing to put in to it.
for the 05 ONLY..you if you go with a 19/42 gears..you WILL need a longer chain..
not sure how long, but thinking 92 pitch or so..i will find it and get back to you..
I'm a little confused with your chart. But if I go from stock gearing to 19/42 what clutching needs to be done? Just weights?
Thanks,
Nolan
i went from running 10-74 and am now running 11-72's. What weights should I go to if i regear? Shouldnt the 19/42 work with the stock chain on the 06?
Thanks,
Nolan
Appreciate it BIGDAWG, So other than heavier weights is their any other clutching that needs to be done? Off topic but does any clutching need to be done when going from a 1080 to a 1115 belt?
Thanks,
Nolan
I had the dealer switch everything over for the 115 belt at the beginning of the season. He set the deflection and such, but never changed any springs. This is also the time when he went from the 10-74's to the 11-72's. Right now all my clutching is stock, primary and secondary.
