Upgrade to Premium
Reply
  #1
Old 12-28-2008, 12:53 PM
sleddawg01 sleddawg01 is offline
Currently: Not set.
Basic Member
sleddawg01 has a reputation beyond reputesleddawg01 has a reputation beyond reputesleddawg01 has a reputation beyond reputesleddawg01 has a reputation beyond reputesleddawg01 has a reputation beyond reputesleddawg01 has a reputation beyond reputesleddawg01 has a reputation beyond reputesleddawg01 has a reputation beyond reputesleddawg01 has a reputation beyond reputesleddawg01 has a reputation beyond reputesleddawg01 has a reputation beyond repute
Default '05 800 Rev...How do I test stator and coil?
Just wondering...having trouble starting my 05 800 Rev. Wondering how to test the stator and coil and where the damn stator is?
Rate this post: Yes | No
  #2
Old 12-28-2008, 02:00 PM
ak ak is online now
Currently: Nothing
ak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond repute
Default
The stator is behind the recoil there will be some electrical plugs coming out of the case to tes read this. PXYLE gave a good example:
I have seen the wire from the DESS post, the Black/Green one, have a bad connection and cause the exact same problem, also seen bad DESS posts do that.
No need to pull the stator as you can check continuity while in the sled: check each yellow to the other yellows and you should have about 0.7 ohms ( 3 tests ) and check each yellow wire to the engine ( ground ) and you should have no continuity. If when you test from the yellows to ground and you have continuity, then you need a new stator.
Also have seen bad MPEMs do that. If you have a friend with the same year of sled, try swapping MPEMs and keys at the same time, then try DESS posts.
Just my .02....
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
