Upgrade to Premium
Reply
  #1
Old 11-26-2008, 11:18 AM
chsdaddy chsdaddy is offline
Currently: Jonseing for some SNOW
Basic Member
chsdaddy has a reputation beyond reputechsdaddy has a reputation beyond reputechsdaddy has a reputation beyond reputechsdaddy has a reputation beyond reputechsdaddy has a reputation beyond reputechsdaddy has a reputation beyond reputechsdaddy has a reputation beyond reputechsdaddy has a reputation beyond reputechsdaddy has a reputation beyond reputechsdaddy has a reputation beyond reputechsdaddy has a reputation beyond repute
Default Arctic Cat Transmission Lube
I looked around for a little while and there are a lot of people using a lot of different stuff in their chaincases with no problem. No AC dealer is close by and I have at my disposal: ATF, Transmission Fluid (90w and synthetic), motor oil (20-50W), Delo 400, and lower unti Lube for an outboard.
04' MC 800, clutched for 9000+ 144 2'' track
What is most like what is specified in the manual as Arctic Cat Transmission Lube PN 0636-817?
Rate this post: Yes | No
  #2
Old 11-26-2008, 03:31 PM
FanMan FanMan is offline
Currently: Not set.
Basic Member
FanMan is an unknown quantity at this point
Default Diamond Drive lube
Yea, I've done a little research and ordered some Amsoil synthetic marine gear lube. I chose the marine lube because it should resist the foaming action if moisture builds up in the diamond drive. Plus it's supposed to handle the higher pressures of the gears meshing...we'll see, honestly I think any of the oils mentioned would work but opted to give the Amsoil marine a try.
I'm gonna drain the diamond drive tonight and inspect the old oil. If it looks alright without metal in it, I'll just add the new oil. It only has about 700 miles since gearing it down and the drive was flushed at a dealer so we'll see.
I did notice a post by racinstation (dealer I believe out of Driggs, Idaho) he recommends hydraulic oil. Many different opinions but it all boils down to keeping oil in the drive unit. Good luck, I hope this helps.
Mark
  #3
Old 11-26-2008, 05:53 PM
Comp 670 Comp 670 is offline
Currently: Dreaming of a timbersled kit...
Comp 670 has a reputation beyond reputeComp 670 has a reputation beyond reputeComp 670 has a reputation beyond reputeComp 670 has a reputation beyond reputeComp 670 has a reputation beyond reputeComp 670 has a reputation beyond reputeComp 670 has a reputation beyond reputeComp 670 has a reputation beyond reputeComp 670 has a reputation beyond reputeComp 670 has a reputation beyond reputeComp 670 has a reputation beyond repute
Default
I think hes talkin chaincase,not diamond drive.
I use good old 90w in my chaincases with no probs.I have used anything from shock oil to atf to anything else you can imangine in a chian case and have never had any probs.Even on watercraft tripples.
  #4
Old 11-26-2008, 06:51 PM
SEAKM8 SEAKM8 is offline
Currently: Not set.
SEAKM8 has a reputation beyond reputeSEAKM8 has a reputation beyond reputeSEAKM8 has a reputation beyond reputeSEAKM8 has a reputation beyond reputeSEAKM8 has a reputation beyond reputeSEAKM8 has a reputation beyond reputeSEAKM8 has a reputation beyond reputeSEAKM8 has a reputation beyond reputeSEAKM8 has a reputation beyond reputeSEAKM8 has a reputation beyond reputeSEAKM8 has a reputation beyond repute
Default
We used lower unit lube with no problems
  #5
Old 11-27-2008, 12:31 AM
samtarolli samtarolli is offline
Currently: Not set.
Basic Member
samtarolli has a reputation beyond reputesamtarolli has a reputation beyond reputesamtarolli has a reputation beyond reputesamtarolli has a reputation beyond reputesamtarolli has a reputation beyond reputesamtarolli has a reputation beyond reputesamtarolli has a reputation beyond reputesamtarolli has a reputation beyond reputesamtarolli has a reputation beyond reputesamtarolli has a reputation beyond reputesamtarolli has a reputation beyond repute
Default
sythetic gear oil from napa, 4 bucks and enough to fill it like 4 times or so
  #6
Old 11-27-2008, 11:23 AM
SnoPro1000 SnoPro1000 is online now
Currently: Not set.
SnoPro1000 has a reputation beyond reputeSnoPro1000 has a reputation beyond reputeSnoPro1000 has a reputation beyond reputeSnoPro1000 has a reputation beyond reputeSnoPro1000 has a reputation beyond reputeSnoPro1000 has a reputation beyond reputeSnoPro1000 has a reputation beyond reputeSnoPro1000 has a reputation beyond reputeSnoPro1000 has a reputation beyond reputeSnoPro1000 has a reputation beyond reputeSnoPro1000 has a reputation beyond repute
Default
i use this crazy oil from a mill into were i live, they use it in the high heat machines that have gears and/or chains i love the stuff, it keeps a nice oil film on the gears like you wouldn't believe. must be good they pay like 75$ for 4 litters of the stuff...
  #7
Old 11-27-2008, 02:02 PM
Pinned W F O Pinned W F O is offline
Currently: Outta Boundz Repair
Basic Member
Pinned W F O has a reputation beyond reputePinned W F O has a reputation beyond reputePinned W F O has a reputation beyond reputePinned W F O has a reputation beyond reputePinned W F O has a reputation beyond reputePinned W F O has a reputation beyond reputePinned W F O has a reputation beyond reputePinned W F O has a reputation beyond reputePinned W F O has a reputation beyond reputePinned W F O has a reputation beyond reputePinned W F O has a reputation beyond repute
Default
Been runnig ATF with no Ill affects.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
