Upgrade to Premium
Reply
  #1
Old 11-11-2008, 11:32 PM
SNOWINTHETOES SNOWINTHETOES is offline
Currently: Not set.
Basic Member
SNOWINTHETOES will become famous soon enoughSNOWINTHETOES will become famous soon enoughSNOWINTHETOES will become famous soon enoughSNOWINTHETOES will become famous soon enoughSNOWINTHETOES will become famous soon enoughSNOWINTHETOES will become famous soon enoughSNOWINTHETOES will become famous soon enoughSNOWINTHETOES will become famous soon enoughSNOWINTHETOES will become famous soon enoughSNOWINTHETOES will become famous soon enoughSNOWINTHETOES will become famous soon enough
Default Triton Trailer : How to change the lights out?
I have a 2004 Triton Trailer, single place. I have right brake light out. I go to look under the trailer end, and there is a square tube that runs along the whole back side. The front of each light has a large rubber grommet surrounding it. I am not sure how to get the light out.
I went to tritontrailers.com and got the parts diagram, but it says that the lights usually have to be replace with the housing as well.
i just can't seem to figure out how to the get them out.
Can you let me know if you have done this before? Thanks.
Rate this post: Yes | No
  #2
Old 11-12-2008, 06:02 AM
shortman's Avatar
shortman shortman is offline
Currently: wating for first ride of the year
shortman has a reputation beyond reputeshortman has a reputation beyond reputeshortman has a reputation beyond reputeshortman has a reputation beyond reputeshortman has a reputation beyond reputeshortman has a reputation beyond reputeshortman has a reputation beyond reputeshortman has a reputation beyond reputeshortman has a reputation beyond reputeshortman has a reputation beyond reputeshortman has a reputation beyond repute
Default light change
Take a flat screwdriver and pry between the black grommet and the light, its kind of a tight fit but it will come out. Be sure and have your new light before you unplug all the wires( 3 wires- stop/turn--clarence--ground) makesure and plug them back into the new light the way they come of the old one. When you put it back into the grommet use some glass cleaner or something slippery/spray light and grommet, should pop right back in. You shouldn't need to replace the black grommet.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
