Best Spark Plugs and Gap on Turbo with race gas?
Mr. Pump Gas
218
26
What is best plug to run and gap with 100% race gas? Sled is 2012 BD turbo 800.
Thanks in Advance
Mr. Pump Gas
218
26
This is with factory head. Thinking about running avgas this year. Just running Standard BR NGK plugs. Foul once in a while. What is everyone running?
kgra
237
89
British Columbia
Factory plugs work fine. I prefer the iridium in factory heat range just for the extra insurance. Best suggestion is to make sure the spark plug terminal is solid not threaded. That way you don't need to worry about the terminal coming loose and spark arcing out in the spark plug boot eventually causing high resistance and poor performance.
B
Boyko
771
260
Alberta
If your going through plugs its a tuning issue. A rich mixture even at idle will foul plugs. You can only get a bog so many time before your plugs need to be replaced.
Its not easy to avoid on a t-smoke.
