2006 rmk 600 compression
Nov 2, 2011
17
1
3
41
Hello everyone. I am new to the sport of sledding and I am looking at get a 2006 rmk 600. The sled had 3500 miles on it. I was wondering what the compression should check out to? I am looking at picking up soon. it seems like a good price. But I want to to make sure the engine is tight. anything helps
C
chunkysoup
1,458
151
Waterloo, WI
good compression should be between 120-130psi higher is better but lower you may be looking at a rebuild. Probly close to time for a rebuild anyway with that many miles. Hope this helps.
Goinboardin
1,409
820
Laramie, WY
It is altitude dependent. Not the actual C/R but what a standard compression tester will give you in PSI. So a healthy motor at 300' might read 150 psi then take that measurement again at 10,000' and you might see 108psi. Its still a healthy motor at 10,000', its just the air density is significantly lower at that altitude.
Also, a ported motor may read lower with a compression gauge than a non-ported motor because the cylinder isn't "sealed" as long during the compression stroke, but it will flow more air and make more power.
I had an Indy 500 that read 80 psi cold at 7700', and it was healthy (just broken in from a rebuild actually). Never did check what it read at low altitude though.
Just some food for thought.
C
chunkysoup
1,458
151
Waterloo, WI
if you had 80 psi where i am around 1000' the engine wouldnt even run! you'd be lucky to get it to run at 90 psi. But yes elevation will play a role in compression.
