Yep, I would say so,
Pulling the stator, On my 1000 I had to take the throttle body out of the boots in order to clear the oil bottle, hopefully the m8 has more clearance than m 10, If not you will need to remove oil lever, should have enough play in coolant lines and throttle cable to just move it to the side, the intake boot is a pita, take a channel lock and pull on the bottom of boot, should come out with a couple tugs,
taking the flywheel off, you can get a steering wheel puller that will line up with the bolts on the flywheel, however I have never been able to remove a cat flywheel with this kind of puller. I made my own out of 3/8 plate steel. Use the recoil as a templet to drill your 3 holes, the steel has to be 7" x 4" approx. Do not remove the outer housing until the fly wheel is removed. You span the housing with the plate steel. You will need to go to ace or any hardware that has metric bolts by the piece, get a couple different lengths and washers, I think 1 1/2 to 2 inch will get it, also get several washers to shim if you have too long of bolts. Place the metric bolts into the flywheel 1/4 to 3/8 of an inch where they are tight, start going around the circle 1/4 turn a time until it pops which usually is not long. So you are bracing against the outer housing rather than pulling off the center bolt, I know this sounds *** backwards but it works and will not damage the flywheel.
