Primary clutch springs
M
Jan 14, 2017
10
I would like to change the primary clutch spring so that the it engages between 2500 & 3000 RPM's. My current spring is yellow/white, which engages around 4500 RPM's. Can someone tell me what the clutch spring options are for a 2007 M8 162" track and at what RPM they engage?
M
Oct 4, 2015
538
147
Montana
Springs
Search this forum, there are some spring rates & charts posted. That being said, it seems that on the older M's, the ECU mapping & the heavier older AC clutches need a higher starting rate spring. Most springs @ a lower initial rate than the W/Y (lower engagement rpm) usually resulted in an engine bog! A reasonably tight .015 belt to sheave clearance can give a smoother, albeit high, engagement.
