M8 leaking coolant into motor
M-Head
165
24
Yakima, WA
I have a turboed 2007 m8 that has an elusive coolant leak into the motor. I've replaced the head gaskets and base gaskets, but it continues to leak about 16 ounces per ride through the motor. Does anyone have an idea what it might be? Any help is much appreciated.
Jan 14, 2012
230
62
Cracked cylinder?
How do you know its leaking into the motor?
I dont think the motor would live to long eating coolant.
M-Head
165
24
Yakima, WA
When I pull the pipe I can see a tan color in the y-pipe and moisture. I have no antifreeze leaking in the belly pan, tunnel cooler or anywhere else. I replaced the head gaskets first, and it still leaked. Then I did the base gaskets and head gaskets and still leaking.
F7arcticcat
75
I had a seal or bearing go out of the water pump impeller and it was leaking into the motor, this was leaking at a fast rate though.
