D
Got mine and it did take a bit of heat to install it
Bit of warning and advice to others
When I installed mine, it cut a sliver of plastic off the tank itself and luckily I saw it before it sunk into the oil.
So just be careful and look into the tank after install
The edges could be a bit smoother to avoid this
good point to note .. Bottom I noticed on some sleeves here had a sharp edge .. I took emery to dull it down .. Check sleeve when you receive just to be sure not sharp .. I catch pretty much all of em tho .. Thank you for that feedback
