R
Hello having problems getting my cold air intake to fit on my male ends I of my top pod I cut off 1/2 inch like it says do they go inside or just rest on top ?
Note: this_feature_currently_may_not_be_available_in_some_browsers
As madmax said you will have to shorten both the dash pods and the evo tubes to get a good fit. Also the instructions say to put the bottom of the airbox back on over the evo V-Flow intake. This is not required and will be changed in the next instruction revision.
Woody
So the ones I have put on over the course of the last few months- I can go ahead and pull the cover off my clients sleds?
Any heat issues even if running the balnkets from Jim?
S/C
WMP llc
I have run about 300 miles without the cover on. It actually opens up more under hood area for heat dissipation. Jim told me it was not needed and he was going to update the next set of instructions.
Woody
