W
I've been having an issue with my 2012 RMK (Standard). When I first bought it, it was having an issue fouling plugs. I thought that this was because I am a new sledder and not pinning it like I should. Compression good, 120 PSI each side. I had the TPS reset at the dealer and this seemed to help some. It would still carbon/fuel foul until I cleaned my exhaust valves. Much better now. Although the other day, went out and never hit WOT due to terrible light. Poked around in the trees and came home. Started it up and wouldn't idle (it was around 1400 like previous) pulled plugs and all black. Replaced plugs, went out for a full day in deep heavy spring pow, WOT a lot. Slow on the way out due to heavy whoops for 4 miles. Came home and checked both plugs, half black on the intake side, half white/silver/brown on exhaust side. Any ideas as to the cause of this?
Also, low on coolant, about an inch from the line. It was really warm and I hit 180* on the thermostat. Is this normal to loose some coolant on a warm day like this?
Thanks for the help!
Ty
Ty
