I'm running an 09' d8 kpa 2871 turbo with a 10' block and spi t-molly series pistons and the 09 "fix it" recall low comp head at 7-9 psi. I run 50/50 AV at a lowest elevation of 4.5k and 12.8-13.2 AFR @ WOT. I started at 20% AV but I had to keep raising the mix till I stayed off the DET sensor, that happened @ 50/50. I'm surprised to see how little you guys are mixing at much lower elevations...
What is the compression rate of that head?
