Throw on a "boost T" controller and you'll get what you need without the spring work.
Just put in a low force spring... small yellow or small red (depending on the model of TiAl WG you have)... The controller will not 'switch' open the WG till you reach the desired boost....
What exact model of TiAl WG do you have (EG 'F38, 'V44' etc)
In conjunction with the Boost-T, you want to use a spring that has a rated force just below what your lowest boost is....no too low, as this can then be affect WG opening with pipe pressure.
Also... I'm taking for granted that you know that your boost gauge will read higher as you rise in altitude above sea-level for a given Manifold pressure??
Plus, it will give a bit crisper function of the wastegate.
AMAZON $78 with free ship
http://a.co/4u9tT9e
