U
2009 m1000 snopro 153 1250 miles I can't get this cat to run guys I've spent over 2,000 at dealers and no luck! It loads up on mag side cylinder and can't get it to clean out! Here is the list of stuff I've done. Cleaned and flopped injectors cleaned and checked powervalves changed ecu and injectors stator coils plug wires flopped them around and changed wires with no difference!!! Reeds servo chassis control module fuel pressure is in spec according to dealer maybe still to high!? This sled is all stock I bought it sight on seen from a crook that said it was 100% straight and like new but he hit a tree with it pretty hard and it hasn't run since the day I had my brother pick it up I can't sell it and it's to nice to part out so I would love to solve this problem it loads up on mag side and fouls plugs u can feather the throttle and get it to clean up a cross the field runs like a scolded cat then u let off turn around and same thing bogs around powervalve 6-6200 range and won't open up!! Very frustrating!!!!
