C
Hello folks, Got out for the first time this season ( I know, been busy) Sled ran great! Just one problem, at WOT the sled rev's up and goes, but once it reaches 9000 RPM it bogs down to 8K. Then it takes off back to 9K, and keeps repeating. Also, if you snap WOT from IDLE it bogs down, if you snap WOT from 1/2 throttle or so it rips up to 9K. Reading the plugs they seem to be running about perfect, just a touch of grey on the electrodes. Clutching/gearing is as recommended from SLP. Running the factory Yamaha belt. It's got the SLP triple pipes, vforce 3 reeds, and a "boost bottle"(balance tube on the intake manifolds/boots) and the shelf is removed from the airbox. I was going to try and richen it up a touch and see if that helps, but any input you folks have would be greatly appreciated. Thanks, Brian
