Arctic Cat Tools
h2arctic
459
30
Colorado
0444-186 FLYWHEEL PULLER (E001)
0444-188 STARTER ONE-WAY PULLER (E006)
0444-187 FLYWHEEL PULLER (E003)
0744-074 TOOL,FUEL PUMP INSTL-'12 F4 W/INSTR
0444-161 PULLER,DRIVE CLUTCH-650
0644-516 WRENCH,BEARING NUT - JACKSHAFT
0444-104 DRIVER,48MM - INTERNAL HEX
0644-415 SOCKET,BRAKE DISC NUT
0444-191 STARTER ONE-WAY NUT WRENCH (E015)
0644-458 TOOL,SLEEVE-SHOCK PROTECTOR
0644-557 KIT,TOOL-WATER PUMP BEARING / SEAL
0644-242 WRENCH,CABLE-10MM
0744-069 KIT,ECU REPROGRAMMING-800
0444-127 TOOL,REMOVAL-PINION GEAR & SHAFT
0444-271 WRENCH, DRIVEN CLUTCH HOLDER W/INSTR
0644-320 BAR, CLUTCH ALIGNMENT
0644-427 ALIGNMENT BAR,CLUTCH-ACT 1.655
0644-588 ALIGNMENT BAR,CLUTCH-1.450 OFFSET
0444-126 TOOL,SEAL PROTECTOR
0444-269 COUNTERBORE,.406" HSS 4 FLUTE W/PILOT
0544-011 TOOL,BACKLASH MEASURING-27T W / INSTR
0644-380 CLUTCH HOLDER, ARCTIC 33MM
3639-891 KIT, TPS ADJUSTMENT TOOL
0744-035 HOLDER,CLUTCH-COMET-PTD BLK
0644-570 PULLER, IDLER WHEEL-KIT
0744-020 KIT, SHOCK INFLATOR TOOL KIT
0444-140 TOOL,DRN PULLEY COMP375/400
0644-595 TOOL,BEARING-MOVABLE SHEAVE-W/INSTR
0444-247 HARNESS,ELECTRIC CHOKE TEST
0144-311 REAR SUSPENSION TOOL
0744-023 PULLER,DRIVEN CLUTCH
0644-100 PULLER,DRIVE CLUTCH
0644-096 PULLER,DRIVE CLUTCH
0444-255 TOOL,VALVE GAP - SHORT SHANK
All the tools are used they came from a dealer who went out of business
Want to sell as a complete package.
Make offer
H
Mar 13, 2013
12
Make offer
Did you ever sell all these tools?
