Engine Tech 900 M7 specific tuning information
vinpie1
441
21
18
Gunnison, Co
I have searched over and over again looking for m7 specific tuning information for Engine Tech 900 big bore engines with no luck. The builders #'s are so rich they wash the plugs. I am asking others to share their specific setups and #'s if they have them. I just want to compare them against mine. Also wondering what rpm this motor likes best up in the mountains. Single pipe or twins? I have both.
P
powderman800
250
14
18
Kennewick, WA
Anybody?
I just purchased a 2006 M7 w/ engine tech 900 kit on it and Jaws big bore specific twin pipes. I'd like to know what anybody else is running for jetting for 3-6k elevation?
manlye
480
106
When I had my ET900 with twins, I called Racing Station and had him create a map for the Power Commander, was tired of messing with numbers.
vinpie1
441
21
18
Gunnison, Co
Setup: 05 M7 LE 162- Engine Tech 900 w/ y-pipe, speedwerx single pipe, skinz m7 can, v-force 3 reeds, stock intake/airbox, 2.5* key, 40:1 premix
Elevation 8,000-10,000ft.
My boondocker numbers are:
range lo mid hi trim
3000 02 02 02 01
5000 06 06 06 01
6700 14 14 14 01
7300 14 14 14 01
7800 14 14 14 01
8250 14 14 14 01
8700 15 15 15 01
B
57
Lake Tapps, Wa
Here's the numbers I'm running in my 06 m7 with a Cutler 800 and slp twins. I could dial it in a little better but its good to ride.
RPM LO MD HI
3000 -2 -4 0
5000 -2 2 0
6700 0 6 0
7800 0 4 14
8100 0 4 14
Comparatively you're using a ton more fuel in the middle than me. In theory no need to add to the low setting after 6700 because the throttle position will be in the mid to hi range and you don't need to pour more fuel to it when chopping the throttle. It'll run rich when working the throttle set up like that.
