Rivets
Volvokvaloya
352
23
40
Northern Norway
What rivets do you guys use when replacing tunnels or bumpers..aluminium or steel rivets..and what size..i measured 4,3-4,4mm diameter holes.
I need some black ones since I have a Nightfire edition.
arctic2009
1,864
670
Minnesota
steel rivets, and 3/16" diameter. Length depends on location of where you will be riveting. PN from cat for a black rivet used in the tunnel is 8060-504
4,074
2,794
It seems that cat switched to a rivet just smaller than 3/16". Metric? Not sure what year they started that. The ones that hold the coolers in the corners of the tunnel seemed to be slightly smaller yet. I always just ream the holes to 3/16 and use Napa rivets when I can on bare aluminum. Steel ones are needed. I tried using aluminum ones once on a rear tunnel section and they didn't last more than a couple seasons before they got loose. For black ones I think you are stuck going through Cat. Get the rivets first and measure them.
skidooboy
330
central lower michigan
Yamaha makes a "ringed" rivet, that has washer type rings in it in several areas to match the thickness you are working with, to tighten the components better than most other rivet styles. Ski
arctic2009
1,864
670
Minnesota
I have found that if you buy cheaper quality rivets they are not always spot on with their diameter. Steel quality rivets fit in the 3/16" hole just fine. Ive rebuilt 4 dfferent M series/crossfire chassis and used all 3/16" rivets and 5/32" rivets for the tunnel coolers.
Volvokvaloya
352
23
40
Northern Norway
ok so its 3/16 in the chassie/tunnel and 5/32 in the tunnel cooler..good to know.
Now i only need to find black steel ones...anyone know if Polaris/BRP/Yamaha make some?
kanedog
3,106
3,862
Stavex rivets. They are structural. Get them at rivet stop online.
