W
Hey guys,
Let me start with my sled and some info.
2013 Polaris RMK Pro 800
Just did a top end rebuild with:
Wiseco Pistons, rings, pins, and bearings
"Durability" spacer
V-Force3 reeds
all new gaskets
new plugs
new ignition wires and boots
tps adjustment
And i have A LOT of backfiring on startup and while idling. I had to adjust the throttle to keep the idle up because it has a very low idle. I originally thought it was flooded because i actually had this issue before so i took the cylinders off again to check ring gap again, all good, and saw a lot of fuel and oil in the y-pipe.
Does anyone have a clue whats going on?! I feel that I've tried everything
"Durability" spacer
V-Force3 reeds
all new gaskets
new plugs
tps adjustment
