13 Pro dies
Cat man doo
189
46
Ok, so here's the story on mine! "2013 Pro with Boondocker Turbo, Boondocker box, when new plugs put in, the sled fires up and idles good, then idle slows down and picks up again, then when warmed up it will rip for about 200m then quits like you hit the the kill switch, also won't start after and plugs were somewhat wet. Happens each time with new set of plugs the same. Any idea guys. Put new tether on it as Pingle was faulty and it's still doing the same.
K
Kyle91rs
Jan 23, 2011
198
31
Fort mcmurray Alberta
Have you had any luck fixing your issue? My buddy is the journeyman mechanic down at 4 seasons, he does work out of his garage. I can set you up with him. If he can't fix it no one can. Give me a text, 7803815296.
