So I have an 06 XF 700 that died last winter. I drug it home and discovered there was no spark. I took out the coil and put it in another sled that ran and then that sled wouldn't run. Put original back in the other sled and it fired right up. I should mention this was late last winter. I just recently picked up a coil for it (I have other sleds to ride) and went to install it and had trouble figuring out how it was oriented. I srewed it down directly to the bulkhead, not knowing if this was right as I can see the threads of the scews between the bottom of the coil and top of bulkhead...doesn't look right. I also had a hard time getting the plug caps on the plugs as there was barely enough length to reach. Then I find out that there is still no spark. I pulled on the thing for 10 minutes and nothing. I've unhooked the key and also the tss to no avail. The caps are screwed tight on to the leads. Have I mounted the coil wrong and that's my problem? Can't hardly believe the stator went out at the same time. Is there something between the coil and the bulkhead that I have forgotten? (happens more often as of late)
