K
I would just ask if you have any pictures of pro rmk proven designs snow flaps long? 17,25 -24 post pictures here please
I mounted it on the inside of the tunnel so it would lay flat against the close-off panel. I notched the corners on the bottom... 3"x2" just so it wasnt a sharp corner...added the strap so when I couldnt suck it in the track if I was in reverse...:face-icon-small-coo
Btw, tell me about the little solar panels I see between the bumper and tail light.
Thanks flap is very nice is the logo is always on top or you can chose where to sit if you choose the logo?
He'll move the logo to wherever you want it. I asked him to move it toward the top of the flap in case I wanted to trim the flap shorter... Very easy guy to work with, just let him know what you want
I had the same flap this past season on an 11 Pro, mounted on the outside with stainless allens, just to help keep it abit farther from track lugs. The corner cut will really help - very easy to snag the corner walking around the sled. These do come very long, with a Fox Evol, mine will almost touch the hardpack with sitin. You can cut to any length. I did see better cooling on trails compared to 2011, and worse conditions. Didn't require as much speed to keep temps down, more manageable.
anyone have a part number for that flap?
