The simple way is to unhook the fuel line from the throttle bodies and pull the rope. With the key and kill switch on obviously. If it is pumping it will give you a pretty good shot of fuel.
If you need a new one dont buy it from cat. to expensive. here is the exact same pump that is in it now.
Find the connector coming out of the tank. I believe it is on the right side facing the engine but dont quote me on that. Unplug it and put a test light on the engine side of the connector. From one pin right to the other. Then pull it over, if the light lights there is power and ground to the tank. Then you can use a 12volt battery and put power and ground to the tank side of the connector. With that hooked up you should hear the pump buzz or hum in the tank. If so far so good, then you need to plumb in a fuel pressure gauge and run the pump. I am not sure on the 1000cc PSI spec. If any of the above is missing then follow that lead.
So I tested the fuel pump and all that happened is a shock or click. No fuel pump action ( not pulsing or anything ) is that what they do or is it bad?? Thanks in advance!
If you're saying you put 12v power to the connector right at the pump, and the pump didn't run, then yeah, you need a pump.
I made a little harness with spade connectors to hook up my 12v cordless drill battery for whenever I need to test or prime a pump, works awesome.
Another thing you will want to look at if your fuel pump stopped working/locked up is shine a flashlight in your gas tank. You will likely see a lot of shiny brass flakes in the bottom of the tank, this is from the brass internal gears of the fuel pump. When you go to put a new pump in you should get all of that cleaned up from inside the tank. The brass in the bottom of the tank is usually an indication ahead of time that your fuel pump is going to quit working in the near future FYI
