The MadFab EZ Boards are designed to fit like a stock part. They are machined with reliefs on the underside to fit over all the ridges, rivets and flanges. EZ's don't just lay on top of the boards like these other versions.
They also do not require any cutting, grinding or guessing. Just mark, drill and rivet/bolt. EZ.
And if you want, you can always cut more material out to make the holes larger too. And add more hardware if you think you need more.
They come with stainless hardware and advanced rivets. This and the extra machining and design are the reason they cost a few more $$.
[/URL]
