Is this a plug and play setup?
How much do you have to cut and fit your self, except of the vents?
Everything is in his kit, comes with all the vents, a new bracket for the gauge, which also puts a new vent up under the windshield that should let out a ton of heat. I just used a piece of white chock layed all the vent up on the hood traced then cut them out with a jigsaw. I'm not very patient but the next step is gluing all the pre filter material to the metal frames of the vents. The way to do it would be to glue every one, let them set over night and then come back the next day and trim the excess material away. I just glued them and cut away the excess with a razor blade while it was still wet. Definitely more time consuming the way I did it but it allowed me to just get it all dont at once. If you have a jigsaw, a drill, and some patients its easy to do. It also comes with pre cut stainless steel mesh to put under all the pre filter material so they should be pretty tough.
His email is
grimrepr.1967@yahoo.com
and his screen name on here is ReaperMotorsports
