6
ok so i just picked up a coupe vertical escapes. 800 works great, the 700 runs terrible. heres what we checked so far:
carbs (cleaned and even swapped with known good ones)
crank seals
spark plugs
swapped coils
checked fuel pump
swapped temp sensor and det sensor
checked pulse line to pump
checked stator and flywheel
removed exhaust/checked for restrictions
it has a slp high flow airbox, other than that its stock.
it seems to run on one cylinder at idle and low but both at WOT
compression is 125 on both
fresh gas of course
cleaned carbs
cleaned exhaust valves
gonna try ecu swap with another sled (800 will work i assume?)
crank seals
spark plugs
swapped coils
checked fuel pump
fresh gas of course
cleaned carbs
