Y
I have a 2011 rmk 800 with 3400 miles on it. It has the BMP duribility kit in it and it doesnt seem to like to idle. Is there an adjustment that can be made to get the idle up? Or something common that causes this?
I should clarify that it was my reeds I was talking about and not the cylinders. Once I got the machine started I had to feather the throttle or the RPM would go down to the point the gauge would flicker on and off. It was because of the cracks in the reeds. Replaced the reeds and all is well.
lol thanks for clearing that up how hard is it to get to the reeds
Another problem that it has been having is sometimes the sled will not wanna start you will have to pull and pull and pull. Then sometimes if a little throttle is given it will fire up but you will have to feather the throttle to keep it running. Also i remember a few times this year it would loose power almost like it was running on 1 cylinder but after a few seconds of doing this it would snap out of it and run perfectly fine. Could this also be reeds? Or TPS? Anything else?
Do they sell just the reed pedals separate from the whole assembly? Just curious.
