Yes... I assume you have the Camplast 9174M track?? ... With that track Run the AVID drivers.
I worked with Robbie at Avid a few years back to come out with new style driver for these tracks... smoother than the center drive configurations... and much smoother than the old school "Whal Bros Style" drivers that ride on top of the steel track clips.
Is your 2015 "PRO" truly a "PRO RMK" or a PRO-Ride Chassis "RMK"... ie, does it have an aluminum driveshaft or a steel one?
This driver if you have a chaincase equipped sled... with Steel Driveshaft (AKA ...Std. RMK) very popular choice in 2015)
CLICK HERE
Or This if you have a Quick Drive (belt drive) equipped sled... With an aluminum driveshaft (AKA..."PRO-RMK")
CLICK HERE
A small consideration...You will need to cut the nose of your rails to clear the drive teeth... (shorten by about an inch)
Many people make a big deal about this... but for me... and hundreds of other that I've talked about this with...ZERO issues.
Run a nice "Anti-stab" kit on the front of the trimmed rail for good extra measure.
CLICK HERE
Make sure you run factory tension, as prescribed in the owners manual, on the track... Tracks looser than that cost you performance.
Also...if the sled has any miles on it at all.. when you have the skid out of the sled... Pull out all the cross shafts, clean the tubes and shafts and re-grease with a good grease... good time to service the spring adjusters as well.. both outlined in separate threads.
