P
hope i'm posting this correctly - don't post much..
2012 Pro w/ Silber turbo & SLP air intake.
Getting gauge lifter from MadFab w/ boost & AFR gauge mount. 3 questions:
1) pics from anyone who has installed the gauge lifter with boost gauges showing how you routed the tubes/cable from the boost & AFR gauges. Any using some kind of quick disconnect for taking off hood?
2) those that have lifter with boost gauges mounted to top - after putting some miles on it, do you like this position or do you think they would be better mounted on the side of the gauge lifter? does it hold up when you roll your sled over... those gauges are kinda up there...
3) for those with SLP intake kit - did you block off the vent so hot air isn't flowing into the back of the SLP intake?
thanks in advance guys. much appreciated!
