So AC is not letting the cat out of the bag on the 2012 weight sleds. The only thing they say is the 2012 M8 is the same as the 2011....that puts the 2012 M8 at 468lbs dry. I may be a bit cynical on AC not showing weights for there 2012 sleds but I compare it to online dating....Theres a reason why the pretty girl in the add doesnt give her weight:face-icon-small-win
I also found this spec sheet http://www.arcticcat.se/source.php/1346845/arcticcat_snoskoter_2012.pdf
That gives the weights on the 2012 AC sleds in KGs....granted this isnt for the US, but the numbers they give when you converter KGs into LBs align with what AC claims the weights to be for 2012 on the M8. I like the look and what AC is doing with there new sleds....I think they will sell pretty well.
2011 M8 153 163hp 468lbs 2.87lb/hp
2012 M8 153 163hp 468lbs 2.87lb/hp $12,400
2012 11T153 177hp 548lbs 3.36lb/hp $14,200
2012 RMK163 152hp 438lbs 2.88lb/hp $11,999
